EA82 SPFI to EA81 trike help!
14 replies to this topic
#1 tweety
tweety
    USMB Regular
  • 345 posts
  • Euroa Victoria Australia
Posted 22 June 2013 - 07:13 PM
Been a while since I've been on here.  Got my Tweety trike in Oz. with eA81 and a sC12 Toyota supercharger with a VW auto 3 speed transmission.
For poor economy reasons have decided to convert the EA81 to EA82 SPFI, a common conversion in the USA I see but not so here down under because we didnt get SPFI here. Also the converison might have a few extra issues bacause it isnt a Brat or Leone in that the wiring loom isnt Subaru.
The SPFI kit containing its components form the States includes the loom, manifold, ECU, dizzy with eA81 driver gear and TB.  However the following pictures are of a unit I believe to be the MAF sensor on the snorkel with 3 pins. I dont have a loom section for this unit.  I've seen on some pictures on the web that the wires go straight into the Subaru loom near the guard eg they dont go into the loom at the rear of the TB.
Can you guys tell me how it is hooked up to the ECU or where the connections go?
Thanks in advance for any replied and pictures if possible.
#2 Crazyeights
Crazyeights
    Crazyeights
  • 1,430 posts
  • Pacific Northwest
Posted 22 June 2013 - 07:35 PM
Try this page and see if it helps.
http://www.leoneturb...1_SPI_guide.pdf
I can send you a section of harness with the MAF connector if you get stuck.
Edited by Crazyeights, 22 June 2013 - 07:36 PM.
#3 tweety
tweety
    USMB Regular
  • 345 posts
Posted 23 June 2013 - 12:14 AM
thanks crazy eights.  turns out I have that part of the harness.  all good.
#4 tweety
tweety
    USMB Regular
  • 345 posts
Posted 23 June 2013 - 02:17 AM
anyone recognize this item?  it has vacuum in/out, an electrical connection and a push button on the end.  was in the SPFI kit from your neck of the woods.
#5 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 23 June 2013 - 11:32 AM
A vacuum solenoid... IIRC (I am tired, and my memory of details is suspect), there are 2 on a USDM SPFI:  One for fuel-vapor-canister purge, and one for the EGR valve.  I think ours don't look like that, as they are slightly different shape and more plastic-y.  (That may be just the angle/perspective of the picture.)
#6 tweety
tweety
    USMB Regular
  • 345 posts
Posted 24 June 2013 - 04:20 AM
thanks Northwet.  The two solonoids you refer to for the purge and the EGr are in the kit and will be discarded and replaced with resisters (read that from General Disorder on this site).  My feeling is that this one is off another car. Either way it doesnt seem to fit any electrical connectors.
Edited by tweety, 24 June 2013 - 04:21 AM.
#7 Crazyeights
Crazyeights
    Crazyeights
  • 1,430 posts
  • Pacific Northwest
Posted 24 June 2013 - 11:53 PM
None of the SPFI swaps I have done needed that part.
Edited by Crazyeights, 24 June 2013 - 11:53 PM.
#8 BratRod
BratRod
    USMB is life!
  • 577 posts
  • Dallas, Texas
Posted 25 June 2013 - 12:47 AM
Will you be selling the SC setup from the EA81? (sorry to hijack)
#9 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 25 June 2013 - 09:44 AM
could be a idle kicker for ac
#10 tweety
tweety
    USMB Regular
  • 345 posts
Posted 25 June 2013 - 09:52 PM
Bratrod.  Here in Oz I have a few mates into Subaru's and one has been very helpful and lives nearby.  I think he'll get the engien for storage to use between us as needed.  The supercharger I'm undecided about. I will put on a new thread on the SC conversion as I think it is worth it for others to read. The pro's and the con's.
#11 Crazyeights
Crazyeights
    Crazyeights
  • 1,430 posts
  • Pacific Northwest
Posted 25 June 2013 - 10:58 PM
I would really like to read the details on this. Thank You.
#12 BratRod
BratRod
    USMB is life!
  • 577 posts
  • Dallas, Texas
Posted 25 June 2013 - 11:42 PM
Alright, thanks for the response.
#13 tweety
tweety
    USMB Regular
  • 345 posts
Posted 23 July 2013 - 12:35 AM
Update:  Am redy for the install of the SPFI now.  Tackled some hurdles as I dont owna brat/brumby/leone etc so some things are different eg the ECU can go under the dashboard lol.  there is no dashboard!  So it is going to be mounted udner the body on an angle so I can see the ECU light.
Got the O2sensor installed, the fuel filter in location, fuel lines ready and ECU warning light ready on the instrument cluster.
Installation on 3rd August.
Fuel pump- new
ECU waterproof cover bag.
ECU mount. Also relays for fuel pump etc to be housed here.
#14 tweety
tweety
    USMB Regular
  • 345 posts
Posted 30 July 2013 - 04:50 AM
Less than a week to SPFI install.  Have been using my moutned spare EA81 as a mock up for the conversion.  Have turned the air filter top body 90 degrees so it points towards the frotn of the trike.  re- routed valve cover hoses.  Top radiator hose to go over the manifold.
The plan is to re-time the engine to 20 degrees, palce the rotor on No1 cylinder then do the install. any other ideas?
Edited by tweety, 30 July 2013 - 04:52 AM.
#15 tweety
tweety
    USMB Regular
  • 345 posts
Posted 06 August 2013 - 05:13 AM
got all linkages hoses etc connected.  Now the loom install. looking ok.
