#1 cylinder not firing
12 replies to this topic
#1 Frank T
Frank T
    New User
  • PipPip
  • 17 posts
  • Eastern PA
Posted 13 July 2013 - 09:30 PM
1987 GL10 single port fuel injected
Non turbo
Automatic
2wd
55K original miles
I changed the MAF sensor a few days ago (due to non starting). When I got the car started I noticed it was idling rough and even stalled when I put it in gear. So I pulled all the plug wires one at a time (engine running) and when I pull cylinders 2,3 and 4 the engine runs worse. But when I pull #1 wire the engine has no change. So I changed the #1 plug, wires, distributor cap and rotor and pulled #1... still dead. I took the #1 wire off, put the old plug in the end of the wire and ran a jumper wire from the old plug to the new plug (still in the engine) and the old plug (exposed) fires the plug consistantly.
I took the new plug out of the engine and the cylinder has good compression... Which tells me there is fuel issue, but with the single point fuel injection why would it feed all the cylinders except #1????
When in park it idles around 700-800 rpm. In drive it idles around 500-600.
Any ideas why the #1 cylinder is not firing or why the engine is suddonly running rough?
Thanks
Frank T
#2 djellum
djellum
    Eat, Live, Breath Subaru
  • 774 posts
  • Vancouver WA
Posted 14 July 2013 - 02:13 AM
id say the missfire would be number 1 as to why its running rough.
leaky intake gaskets can kill a cylindar and weaken the others, and of course if your vavles aren't opening correctly you can have compression but no intake charge as well.
the SPFI still pulses fuel, but i dont know if it pulses for each cylindar individually or if it just pulses at a rate for the RPM's.
I dont really know off hand what is the most likely, but i would probably check the intake gaskets
#3 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 14 July 2013 - 02:47 AM
+1 on the valves. I had that same problem on my car(carbed) i took the valve covers off and adjusted the valves. Problem solved.
#4 john in KY
john in KY
    1000+ Super USER!
  • 1,631 posts
  • KY
Posted 14 July 2013 - 04:58 AM
Had the same problem once. In my case the problem turned out to be a small broken vacuum line that was attached to the intake manifold runner that fed the dead
cylinder.
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 14 July 2013 - 09:14 AM
87 GL-10 would be mpfi with 4 injectors. maybe your car is an 86?
#6 Gloyale
Gloyale
    It's a sickness
  • 10,544 posts
  • Corvallis, OR PNW
Posted 14 July 2013 - 11:22 AM
Ea82 engines do not have adjustable vavles
#7 Gloyale
Gloyale
    It's a sickness
  • 10,544 posts
  • Corvallis, OR PNW
Posted 14 July 2013 - 11:30 AM
Nope.  Non-turbo MPFI was dropped for the GL-10 in 87.  All 2wd non-turbo cars that year are SPFI  (excluding XT)
86 2wd non-turbo GL-10 would also be SPFI
85  2wd Non-turbo GL-10 would be MPFI
85 4wd Non-turbo GL-10 would be carbed
He's got an SPFI car.
My suggestion would be to do a leakdown, not just a compression check.  Burnt or hung up valve can still show pretty good compression.
#8 Frank T
Frank T
    New User
  • PipPip
  • 17 posts
  • Eastern PA
Posted 14 July 2013 - 09:34 PM
I found a very small vacuum hose disconnected on the same side as the #1 cylinder!!!
I Hooked it up and it smoothed out the idle. Why this was acting like the #1 cylinder not firing??? Im assuming it was pulling vacuum from near the #1 cylinder///
Im just glad it was something simple.
Thanks for everyone's input!!
Edited by Frank T, 14 July 2013 - 09:36 PM.
#9 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 14 July 2013 - 10:16 PM
Glad you got it figured out. Good to know theres no adjustment on the valves and kinda weird also
#10 naru
naru
    1000+ Super USER!
  • 2,235 posts
  • under the bridge
Posted 16 July 2013 - 09:25 AM
Because #1 was not firing.
Vacuum leak leaned out the mixture for #1 to the point of incumbustibility
#11 stichn56
stichn56
    New User
  • Pip
  • 7 posts
  • thornton
Posted 26 August 2013 - 07:39 PM
these engines aren't very powerful anyway. when even a small vacuum leak can feel like a cyl's not firing.
#12 leniac
leniac
    New User
  • PipPipPip
  • 71 posts
  • Chile
Posted 27 August 2013 - 08:08 AM
post a pic o the vacuum hose... for the future problems....
#13 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 27 August 2013 - 08:46 AM
stuck injector try a differnt one have seen them stick faily often
