October 15, 201312 yr Around 285-300lbs dry? For some reason that sounds a little overweight but I figure I will ask here first.
October 15, 201312 yr I don't know, but not long ago, I took a bad EJ-25 I took to a wrecking yard as scrap. A young skinney yard worker with no visible arm muscles reached in the back of my OBW, put his arms around the motor, and lifted it over to the waiting scoop of a front end loader. I was impressed, and told him so...............Let the years roll by, and I bet the guy develops back trouble.
October 15, 201312 yr Author Well I'm 126lbs I've moved two 8D batteries (not at the same time!) which are 145 lbs each over 2,000 Ft i got myself a dolly the very next day! That was the hardest dead lift ever!
October 15, 201312 yr EJ22 is supposed to be 185 pounds. I am assuming this is minus fluids and bolt ons etc.
October 15, 201312 yr I'm going to copy and paste in some input from a topic I started ages ago about ej25 weight. might give you some insight:"I happened to have an ej25block (loaded with innards, flywheel and oil pan but no heads, accessories, or manifolds). That's a short block, right?Anyway I was moving it inside off my lawn due to impending rain and unsightly premises complaints(j/k) and I put it on a scale:140lbs"I think the heads weigh about 25lbs each. add those plus an intake manifold and some accessories and you'd easily make 220+poundsI can't really imagine there being very much weight difference between an ej22 and an ej25. they're so close to the same castings that most of the parts are interchangable
October 15, 201312 yr I could imagine a 2.5 could weigh less than a 2.2 with larger bores. not by much, maybe not even a pound. But my suzuki gs1000 engine weighs less than a gs750 engine being of hte same block design. My colt trooper mk3 /22 revolver weighs more than a .357 with the smaller bore in the barrel. A short block can be picked up and chucked across the room.
October 15, 201312 yr I was wondering why my Legacy wagon only has a curb weight of roughly 3k pounds and not 3400-3600+. I think this explains part of the reason. ^Definitely do NOT lift these things w/o back support or a friend. As someone who fell off a semi and herniated a disc in the lumbar region, back issues are no fun and do NOT go sway (even with surgery) and simple day to day activities are completely screwed forcing extra care or complete avoidance of back-irritating activities. I was 32 when injured (35 now) and 100% healthy/fit. Granted it was a fall, but bad lifting techniques can cause the same types of injuries. *This has been a public service announcement*
October 15, 201312 yr Author I will have help, I just kept hearing at least 5 different weights.. and it figures as soon as I put the engine lift back in storage I gotta go about 8 miles to go get it.
October 15, 201312 yr two people can easily move it all day long. those $7 harbor freight furniture dollys are worth way more than $7 for moving around horizontally. then just pick up and drop in. have towels or cloves if it's greasy. lifting an engine alone depends on you and the vehicle. remove as much weight as you easily can. it's much easier into a wagon that you can heave it onto the bumper and slide in verses the up-and-over of a true trunk like on a sedan. have a piece of material you can lay on bumper - just heave the engine on there and then slide it into the back - easy. on a sedan it's much more difficult - i wouldn't do it alone unless you're very convinced you can - once the weight gets above your waist it's much more difficult to maneuver it that last bit up and over the back of the trunk into the trunk.
