help
14 replies to this topic
#1 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 22 October 2013 - 09:52 AM
I just installed a Subaru 2.5L out of a Legacy in my Baja bug. it seem that the rev limiter is set to 4200rpms is there any way to raise it up to around 6000 rpms ?
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 22 October 2013 - 09:58 AM
It will need to see a vss signal.
#3 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 22 October 2013 - 10:00 AM
+1 speed senser needs imput try a inline speed senser mabee find one on 90s ford thats inline
#4 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 22 October 2013 - 10:41 AM
I can do that.  what pin on the computer is the VSS?  does anyone have a copy of the pin out?
Dalton
#5 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 22 October 2013 - 10:42 AM
this is my first drive with it...  Love the power.
#6 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 22 October 2013 - 11:17 AM
the computer came out of a 1999 Outback Legacy with an auto tranny.
#7 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 22 October 2013 - 08:20 PM
That rev limiter you are hitting is "limp mode". A lack of a VSS signal will put the car in limp mode.
#8 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,973 posts
  • Charlottesburg, VA
Posted 22 October 2013 - 10:30 PM
There's a pin that needs to be grounded so the ECU doesn't look for the auto trans.
Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch.
#9 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 23 October 2013 - 05:34 AM
does anyone have the ECU pin out?
#10 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,973 posts
Posted 23 October 2013 - 07:42 AM
You can find the FSM for 99 here:
http://www.main.expe...u_manual_scans/
Look in the wiring diagram section. ECU pinout should be in there. If not there look in OBD2 diagnostics under troubleshooting.
#11 Rooster2
Rooster2
    Subaru Master
  • 4,706 posts
  • Indianapolis
Posted 23 October 2013 - 07:58 AM
Nice rig....Does the radiator function well at its present location?? IMO, it looks a bit awkward where it is mounted. You would get better air flow if you swapped radiator and spare tire mounting  locations. Something to think about.
#12 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 23 October 2013 - 09:34 AM
Very nice job !!! a 90-92 wire harness from legacy will run that engine and needs no vss to run i use this harness becuse is non obd2 and has no limp mode makes better power to. You may want to think about that harness have had many problems trying to stand alone 95 and up harneses
#13 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 23 October 2013 - 09:56 AM
the radiator seems to work fine. it does 80mph all day long. I wanted to keep the weight down low.
#14 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
does anyone know what pin needs to be grounded?
#15 dalton
dalton
    Newbie
  • Pip
  • 9 posts
  • Peoria AZ
Posted 23 October 2013 - 09:57 AM
Thanks for the help guys..
