pull transmission?
10 replies to this topic
#1 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 29 October 2013 - 08:51 PM
What is the best way to pull a 4 speed single range 4x4 transmission from a stock height 78 brat?Forgive my ignorance but I am used to subarus tall enough that the transmission can just come out from underneath.this 78 sits pretty low...
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,008 posts
  • East Coast
Posted 29 October 2013 - 09:49 PM
not on a brat but i've pulled Subaru engines and trans together on ER and EJ's and that's pretty easy actually.  need lots of clearance for the lift to go up and over the rad support but it's otherwise quite simple considering there's no bell housing bolts to disconnect insitu.
can you get it off the ground and drop the trans from underneath like you're used too?  i've done that before too.
#3 BoxerRebellion
BoxerRebellion
    Advanced Member
  • PipPipPip
  • 114 posts
  • Portland, OR
Posted 29 October 2013 - 10:44 PM
Perhaps, ramps?
#4 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 29 October 2013 - 10:59 PM
Lift it up, put blocks under the tires till you think you can get it out. Or use a lift and tranny jack haha
#5 turbosubarubrat
turbosubarubrat
    2nd gen hoarder
  • 1,838 posts
  • Sandy, OR
Posted 29 October 2013 - 11:16 PM
I took one out of a 78 brat just unbolt everything ataching it to the car plus the shifting/4wd linkage then lift it up with jack stands and pull it out going under either rocker panel
#6 bonvo
bonvo
    USMB is life!
  • 384 posts
  • LaPine, Or
Posted 08 November 2013 - 09:42 PM
bout to say man jack car up put on jack stands drop trans thats about it
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 08 November 2013 - 09:59 PM
I go the route of jacking up the one side of the car to get the trans out past the frame rails
#8 ferox
ferox
    King of the Echo People
  • 943 posts
  • Portland, Oregon
Posted 09 November 2013 - 03:36 PM
I've dropped the trans on my '81 several times.  I used to jack the thing way the hell up to clear the bellhousing.  Installation was a pain that way.  Last time I just pulled the engine and trans together and it was a lot easier.  Installation was way better that way too.  It means draining coolant and unhooking a lot of stuff, but at least you can stand there and do it for the most part.
#9 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 10 November 2013 - 02:48 AM
Some how I am getting the message that not many of you have dropped a transmission from a 78 brat  before.There is a cross member where the radius arms go to that sits directly under the transmission.The only way the transmission is coming out the bottom is if the suspension cross member+radius mount cross member comes off.
EA81/Ea82 transmissions are cake.
#10 bonvo
bonvo
    USMB is life!
  • 384 posts
  • LaPine, Or
Posted 13 November 2013 - 02:55 AM
that is also the transmission crossmember you need to drop it to remove the transmission mount anyway
#11 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 13 November 2013 - 03:25 PM
"Keys to lightweight design, design a component so it serves multiple functions..."
