3500 lb winch enough for a Gen 2 Brat or Wagon?
The rule of thumb is 1.5X the weight of the vehicle. so 2700 lbs X 1.5 = 4050 lbs.A 3500 lb winch might work but then it might also need a snatch block to pull you out of deep mud.It really all just depends on what the conditions are that your winching. If your wheels can't get traction in 2" deep mud that is really slick or you need a little help to get up and over a rock then 3500 will probally be fine,If on the other your buried up to your headlights in mud with the consistency of wet cement then you will need the biggest winch you can afford. Or 2 trucks, 3 chains, and a broken windshield..
I like to run the 5K harbor freight winch,but then again I never got the chance to test it out. :(
Edited by Uberoo
  • 4 weeks later...
