Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
2001 Outback Sedan HD 3.0 VDC - front driver tire locks briefly
#1
Posted 11 August 2014 - 07:23 AM
#2
Posted 11 August 2014 - 08:40 AM
#3
Posted 11 August 2014 - 09:02 AM
it sounds like torque bind.
do you have a flashing AT Temp light on the dash at start up?
i have not heard of this happening in the VDC before,
but i have not heard that it doesn't happen either.
the 01 VDC does not have a FWD fuse.
but it does have a VDC off fuse you can put in.
it is located in the fuse box under the hood,
the fuse should be labeled on the lid,
it is the one closest to the passenger seat, i'm pretty sure.
put a fuse in and see what happens.
i don't know enough to know if this should or will help.
but since there is no FWD fuse,
it is your best shot to diagnose your problem., maybe.
are all of your tires rthe same:
size?:
brand?
model?
tread pattern?
tread depth?
tread wear?
air pressure?
the tires need to match.
Edited by johnceggleston, 11 August 2014 - 09:03 AM.
#4
Posted 11 August 2014 - 09:35 AM
I suppose this could be a front diff issue.
also, has the car ever had a rear diff swap?
Edited by 1 Lucky Texan, 11 August 2014 - 09:36 AM.
#5
Posted 11 August 2014 - 09:43 AM
There is no record of a rear differential replacement.
