sturner91 Posted August 15, 2014 Share Posted August 15, 2014 So I'm new here as well as a new Subaru owner. So far, great car - definitely tops my Corolla S I was driving around previously. Anyhow, I recently picked up a 2014 Impreza(about a month ago). Within the first week or so, about 900 miles, my check engine light came on. I went ahead and took it to the dealership. They told me a solenoid between the timing belt and exhaust could be failing(something that measures a temperature). Not sure what the code is nor can I acquire it without going to a dealership. They went ahead and reset the error and told me a piece of debris(dust) could have gotten into the solenoid and triggered the error. I was told if it comes back to return to the dealership where they will swap the solenoid with the alternate side. Well here I am at ~1500miles with the same check engine light. Does anyone have any idea what is causing this or why this is happening? Obviously its under warranty so I will take it back in for service - just curious why this is happening and if anyone else has experienced this. Sorry for the noob based post - again, new Subaru owner and I was told this would be a good place to come for help. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 15, 2014 Share Posted August 15, 2014 sounds odd the way it was explained to you. a parts store should be able to retrieve the code at no charge . Do that and post the code(s) here. For now, do not concern yourself with any diagnosis the parts store makes and don't purchase anything until the guys here see the code. Quote Link to comment Share on other sites More sharing options...
sturner91 Posted August 15, 2014 Author Share Posted August 15, 2014 Thanks for the input. The dealership just called me and said the code was P000A -- they say the Oil Control valve on the left side is faulty and needs to be replaced. It is under warranty so nothing to pay Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 15, 2014 Share Posted August 15, 2014 OK, seems like a camshaft was not responding quickly enough to the control to alter it's timing - maybe the exhaust cam on bank 2? anyway, seems like they have it under control. Quote Link to comment Share on other sites More sharing options...
papajam Posted August 15, 2014 Share Posted August 15, 2014 They certainly don't have mine under control! I've had not one, not two but THREE slow responding cam codes (P000A, B & C) in the last 2500 miles. The Oil Control Valves (OCV) were switched side to side the first time when the P000B code came up, then an OCV was replaced with the P000C code and just yesterday, another OVC was replaced for the P000A code. The dealer told me they've never seen this before and are "guessing" that it's the oil I used at the first oil change at 800 miles. I ain't buyin it! Quote Link to comment Share on other sites More sharing options...
sturner91 Posted August 16, 2014 Author Share Posted August 16, 2014 Curious about this, but when I got my car back the check engine light was still on, seeing as they haven't replaced the valve yet, waiting for the part to come in. But today when I turned my car on the light went off on its own. Any idea why? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 16, 2014 Share Posted August 16, 2014 The light turns off on its own after a few drive cycles. The number of cycles depends on the code that was set. Have you had the first oil change done yet? That's typically a 500-1,000 mile change. Quote Link to comment Share on other sites More sharing options...
sturner91 Posted August 17, 2014 Author Share Posted August 17, 2014 No I haven't actually. They told me I wouldn't be due till 7500 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 17, 2014 Share Posted August 17, 2014 Have you had the first oil change done yet? That's typically a 500-1,000 mile change. I just went and checked before I +1'ed your comment, was surprised it looks like they changed their stance, now says 7,500 miles for 4 cylinder engines, earlier for 6. http://www.cars101.com/subaru/maintenance-2014.html Quote Link to comment Share on other sites More sharing options...
Stevo F Posted August 17, 2014 Share Posted August 17, 2014 I thought I heard for 2015 they were reducing the oil change interval from 7,500 to 6,000. I never go that long anyway with my cars. I normally go 3,000, but running my new 2014 Impreza on synthetic oil, I might go 4,000 (it only has 1,600 miles so far). As for doing the first oil change at an earlier interval, I've heard varying opinions on that, including that there are additives in the crankcase from the factory that may help to run in the engine for at least 1,500- 2,000 miles or more. I've never done the first oil change early on any other new cars I've had, so I likely won't on this one either. I'm dismayed that there are two recent threads in this forum about problems with brand new 2014 Impreza's- mine has been great so far, but will some issue rear it's ugly head? I plan on letting my wife drive the car by herself on a 600 mile round trip next weekend because all our other vehicles are older (or lots worse on gas). I would assume since it's new- nothing to worry about yet. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 17, 2014 Share Posted August 17, 2014 You NEVER follow the normal change interval for the first change. Even though it has supposedly been all broken in already. For a brand new car, Change the oil and filter at about 500-1,000 miles. If the interval is 7,500 miles, change it again at 7,500 total miles, then go by the normal change interval after that. The reason is that the engine oil that comes in a brand new car is actually OLD. Unless you special ordered the car, that car was built, sat in a storage lot for 3-4 months, and then probably sat on the dealer lot another 1-3 months (possibly longer) making short test drives or being started and moved 30 feet at a time before you bought it. Quote Link to comment Share on other sites More sharing options...
