used car Posted November 9, 2014 Share Posted November 9, 2014 I HAVE A 1987 SUBARU GL and i'm finding transmission fluid in the transfer case.What is going on.How to fix it? Quote Link to comment Share on other sites More sharing options...
Sapper 157 Posted November 10, 2014 Share Posted November 10, 2014 try a bottle of Bars Leaks Transmission STOPLEAK. If its just a seal leak that should do the trick. heres a link http://www.amazon.com/Bars-Leaks-1420-Grey-Transmission/dp/B00754YK2S/ref=sr_1_2?ie=UTF8&qid=1415641290&sr=8-2&keywords=bars+leaks+transmission Quote Link to comment Share on other sites More sharing options...
used car Posted November 16, 2014 Author Share Posted November 16, 2014 can the tranny fluid fill transfer case from a bad seal in transfer case or the one in tranny. I need some help! Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 16, 2014 Share Posted November 16, 2014 This may depend on the transmission you have. For a 3AT, if the seal/s between the Trans and differential fail, the atf will end up in the diff. Quote Link to comment Share on other sites More sharing options...
Sapper 157 Posted November 20, 2014 Share Posted November 20, 2014 I know my transfer case (EA81 4spd standard...woo woo! ) always has a light coating of gear oil on it, but it is such a slow leak that its never been a problem. Quote Link to comment Share on other sites More sharing options...
