TetonDon Posted May 14, 2017 Share Posted May 14, 2017 Ice in rear turn sockets may have caused it Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 14, 2017 Share Posted May 14, 2017 tetondon - we need details on the car. Id the car new to you? any wrecks or work done before problems began? can you expand a little of what symptoms you have? Have you tested voltage at the battery while idling? Quote Link to comment Share on other sites More sharing options...
TetonDon Posted May 14, 2017 Author Share Posted May 14, 2017 Thanks for responding,it started when I put on directionals,speed& tac zero out, came back in seconds after canceling , after 4 times, no blinkers , warning lights no charge, I've hooked alt exciter to bulb to power so it charges, will get codes, I know one was no power to diag. Plug . Checked all basics, good poss ign relay, don't know where that is Quote Link to comment Share on other sites More sharing options...
TetonDon Posted May 14, 2017 Author Share Posted May 14, 2017 Found turn sig. Bulb sockets had froze, flat ting bulb contacts to the point of grounding on socket walls Quote Link to comment Share on other sites More sharing options...
TetonDon Posted May 14, 2017 Author Share Posted May 14, 2017 Haynes wire diag. Showed a circuit from CPU to power circuit box? To most of the issues I have, hazards work, no power to back of turn switch I found list of codes if you want Quote Link to comment Share on other sites More sharing options...
06SubLegTx Posted May 14, 2017 Share Posted May 14, 2017 Ice in rear turn sockets may have caused it Check all your grounds to the chassis.... when they come off, break off because of corrosion the system can not complete what it needs to do. Also, these ground straps/connection that are grounded to the chassis. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 15, 2017 Share Posted May 15, 2017 could be abraded wires in that boot from the body to the hatch too. Quote Link to comment Share on other sites More sharing options...
