ron2368 Posted June 4, 2017 Share Posted June 4, 2017 I have a 06 legacy sedan, tires and brake pads are within 9 months old. Problem I have is only with front passenger. After coming off highway / having to brake from a higher speed there is a mild burning small mostly like a rubber smell from that wheel. Yesterday I got off the highway , braked hard a few times and pulled in my drive. I could smell it, its not strong but noticeable. I cant tell that there is any more heat coming off the wheel than the other side. The hub and wheel did not feel hotter either. By the time I jacked it up and pulled the wheel the smell was gone. The tire has no marks and looks perfect. The only 2 things I could tell was 1 the CV boot was letting some residue that accumulated on the frame( wiped it off and really had no smell) 2 there seemed to be a very light residue over the caliper of grease and dust, I wiped it off that was not very smelly. Pulled the caliper back , it looked the same but the rubber seals were dry ( at least for the dirt on them). Any help appreciated. My wife always complained about the brakes and I had 2 cailpers freeze so last summer I got oem pads and NAPA calipers. And lastly she did have a defective tire explode on I95 about 2 years ago front passenger. I had the car aligned since then and the tires wear even and very steady at high speeds. thanks. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 4, 2017 Share Posted June 4, 2017 (edited) quite possible inner cv boot is slinging grease onto the exhaust. It is quite stinky off hot exhaust. - not like engine oil. if it has just begun, absolute best repair is to reboot your existing axle - very difficult to find a mechanic who will do it, but probably worth the effort/expense over any aftermarket axle. many folks here DIY the project. I've done it twice. definitely stay away from typical parts store rebuit axles. Edited June 4, 2017 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
ron2368 Posted June 4, 2017 Author Share Posted June 4, 2017 I found this on google, looks too easy Quote Link to comment Share on other sites More sharing options...
Olnick Posted June 4, 2017 Share Posted June 4, 2017 Interesting video. Yes, it does look "too easy!" I'd like to hear reactions from some of our axle-gurus . . . is this a good way to go? One tip: Before removing the eccentric bolt from the strut bracket, mark its orientation with a chisel scratch or paint mark. You'll sleep better when you go to reinstall it! 1 Quote Link to comment Share on other sites More sharing options...
