lmdew Posted July 18, 2017 Share Posted July 18, 2017 Friend has a 2002 Outback Wagon. Trans is slipping in Drive. It was run out of fluid. I have a used auto and was trying to find the codes, but I'm not finding the Autos. TZ1A4ZCDCA-RN TZ1A42CDBA-RM Same FDR? Thanks, Larry Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 18, 2017 Share Posted July 18, 2017 No clue, hopefully someone knows. I'm sure you're aware of the last resort, mind numbing task of pulling the diff plug and use paint and counting to figure out the gear ratio. Quote Link to comment Share on other sites More sharing options...
wtdash Posted July 19, 2017 Share Posted July 19, 2017 Larry, This might help: opposedforces.com\parts....>>>Model>>drill down to the parts section>>Train>>Diff (trans) and look under Gear Set-hypoid I can't get there @ work. TD Quote Link to comment Share on other sites More sharing options...
lmdew Posted July 20, 2017 Author Share Posted July 20, 2017 I did drill down on the above site, but I did not see the Trans #'s listed. If all else fails, I'll install the new trans and jack one side of the car off the ground. I'll mark the wheels and put in drive. After 10 rotations of the wheels, they should be in the same location if the Front and Rear Diff are the same. Thanks, Larry Quote Link to comment Share on other sites More sharing options...
wtdash Posted July 21, 2017 Share Posted July 21, 2017 (edited) Edit: TZ1A4ZCDCA What This Fits - See Link, but don't trust it 100%. TZ1A4ZCDBA (assuming that 2 is a typo above) What This Fits - See Link, but don't trust it 100%. Edited July 21, 2017 by wtdash Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 21, 2017 Share Posted July 21, 2017 TZ1A4ZCDCA What This Fits Subaru Legacy 2.5L AT 4WD Base Wagon 2002 Subaru Legacy 2.5L AT 4WD Brighton Wagon 2002 Subaru Legacy 2.5L AT 4WD L Sedan 2002 Subaru Legacy 2.5L AT 4WD L Wagon 2002 Subaru Legacy 2.5L AT 4WD L.L.Bean Wagon 2002 TZ1A4ZCDBA (assuming that 2 is a typo above) What This Fits Subaru Baja 2.5L AT 4WD PICK UP 2002 Subaru Baja 2.5L AT 4WD S PICK UP 2002 Subaru Baja 2.5L AT PICK UP 2002 Subaru Baja 2.5L AT S PICK UP 2002 Subaru Legacy 2.5L AT 4WD BAJA PICK UP 2002 Subaru Legacy 2.5L AT 4WD BAJA-S PICK UP 2002 Subaru Legacy 2.5L AT 4WD Base Wagon 2002 Subaru Legacy 2.5L AT 4WD Brighton Wagon 2002 Subaru Legacy 2.5L AT 4WD GT Limited Sedan 2002 Subaru Legacy 2.5L AT 4WD GT Sedan 2002 Subaru Legacy 2.5L AT 4WD GT Wagon 2002 Subaru Legacy 2.5L AT 4WD L Sedan 2002 Subaru Legacy 2.5L AT 4WD L Wagon 2002 Subaru Legacy 2.5L AT 4WD L.L.Bean Wagon 2002 Subaru Legacy 2.5L AT 4WD Outback Wagon 2002 Subaru Legacy 2.5L AT 4WD SUS LIMITED SEDAN 2002 Subaru Legacy 2.5L AT 4WD VDC Wagon 2002 Since they overlap in a couple places I'd 'guess' you're good to go. Td I am dubiuos of this accuracy for US market. Since hte latter is listed for a 2.5 LL bean 2.5 Legacy. Doesn't exist in US. Also listed for a VDC model???? wouldn't that be a different trans? GT's have 4.44 gears, Regular Legacys and LL beans have 4.11 I wouldn't trust this as conclusive Quote Link to comment Share on other sites More sharing options...
wtdash Posted July 21, 2017 Share Posted July 21, 2017 ^+1 I wouldn't either on review. Will edit later. Quote Link to comment Share on other sites More sharing options...
lmdew Posted July 21, 2017 Author Share Posted July 21, 2017 Thanks wtdash! I'll help my co-worker install and we'll verify front and rears are turning at the same rate. Later, Larry Quote Link to comment Share on other sites More sharing options...
