Kestral Posted August 19, 2017 Share Posted August 19, 2017 Looking for info on a bell housing for a EJ Subaru motor. I am looking a putting one in a ski boat and attaching it to a stern drive. I would prefer one that mounts the starter from the engine side of the flywheel for ease of access but not a major problem if it is from the gearbox side. Any ideas, suggestions or recommendations. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 19, 2017 Share Posted August 19, 2017 Starter is always on gearbox side. In the U.S. every EJ bellhousing is identical in terms of fitment and form. I'd expect the same on other markets. Older ones have 4 bolt bellhousing and later have 8. But they're interchangeable. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 19, 2017 Share Posted August 19, 2017 (edited) There's no feasible way to mount the starter on the engine side. There's too much engine in the way. And if you could, you would need a starter that turns the opposite direction. Edited August 19, 2017 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
ferp420 Posted August 19, 2017 Share Posted August 19, 2017 Theres a guy who make custom bell housings he made the ej to toyota trans bell housing you might even be able to use that one or maybe he will make one for you his site is http://www.billsautofab.com/projects/ he is also on this board good luck and make sure to share what ever you find Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 19, 2017 Share Posted August 19, 2017 easiest way I can think of is to use the front diff section of a 4eat. it could be trimmed down for less bulk. but starter stays on trans side. I have seen EA81 engines setup for aircraft use that have the starter mounted engine side sort of under the pass side head. Required a modified oil pan. Also since the OE engine mounts are not used for aircraft there is no interference from that either. Quote Link to comment Share on other sites More sharing options...
Subaru Scott Posted August 19, 2017 Share Posted August 19, 2017 (edited) I adapted an EJ22 into my houseboat. Made my own adapter from 1/2 aluminum plate to bolt up to an OMC outdrive with GM pattern. First, I got the plate drilled and bolted to the Subaru. Then made an a crank adapter for the OMC drive yoke from aluminum plates bolted together, then turned round. I then made a plate that would bolt to the crank adapter (GM pattern) with a 1" wide wing about 15" long off one side. Then I cut the heads off some 3/8" bolts and turned the ends to a sharp point. I did the same with 2 dowels. I went to the junkyard and found a GM 4cyl. with the correct pattern and set it up with the rear facing up. I bolted my plate to the crank, threaded the sharpened studs into each of the bellhousing bolt holes, and rotated the engine around till the wing was over the point, and gave it a bop with a hammer. This gave me a perfect punch mark exactly from the center of the crank for each set of bolt holes and dowels. Then I took straight and diagonal measurements between all the stud points. Then I drilled a tiny hole through each of the punch marks on my plate wing, just big enough to get the tip of a scribe through. I mounted that on the EJ and then scribed a small arc on the adapter plate in the general location of each hole while rotating the crank, thereby keeping all the perfect distance from center. I then laid out the exact centers with the other measurements, cross checking. It may not be machine shop perfect, but if not its damn close! Close enough for a marine outdrive anyway. This really worked very well. The EJ22 was close enough to the 140 HP that was originally in there, that the prop was fine. But... the bigger problem is the exhaust. Nobody makes a marine, water-jacketed manifold for a Subaru. You will have to make your own. I got by with a fabricated y-pipe that just ran up and over the transom with a muffler on the end. I heavily wrapped the whole thing to keep from burning a hole through the bottom of the boat. But it still got too hot, even with no engine cover, to go over 1/4 throttle for more than just short bursts. I bought a stainless turbo header that I was planning to weld a water jacket around. But I ended up just recently taking the whole works out because I really needed the interior space it was taking up. For the time being, I have a Honda outboard mounted, but a custom EJ outboard is on the drawing board! Edit: the only place the starter would fit with my outdrive was all the way on the bottom. I could not access it easily, so I rebuilt it before installing! Edited August 19, 2017 by Subaru Scott 1 Quote Link to comment Share on other sites More sharing options...
