lmdew Posted February 12, 2018 Share Posted February 12, 2018 I've done a few Auto Trans removals and Installs. The Negative Ground bracket makes a great plate to keep the Trans TC fully seated. During removal: - Remove the Negative Ground Lead - When you have the trans moved back a 1/2" or so take the ground bracket and bolt it to the passenger side upper Trans/Engine Mount. You can use the bolt that was there and one of the nuts from the lower studs - The Ground Bracket 2" long or so will hold the TC in the trans Install in reverse order 2 Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted February 12, 2018 Share Posted February 12, 2018 A great tip. I bent up a little piece of metal to look like the factory tool, bolts to one of the starter bolt holes. It took a weight off my mind, I can tell you. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 12, 2018 Share Posted February 12, 2018 I've never done this but I think I saw someone who used a combination wrench - they bolted through the socket end. yeah - dunno if that would even work for our cars; Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted February 13, 2018 Share Posted February 13, 2018 Seated: Seated: 1 Quote Link to comment Share on other sites More sharing options...
