Stuck E-brake on PS caliper
4 replies to this topic
#1 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 08 August 2004 - 03:15 AM
This is on the '84 BRAT. Been having problems with the PS front brake hanging.
No one here will claim responsibility of pulling E-brake handle, but I know I didn't. Only thing I can think of as to why it's stuck on, is that the handle has been pulled.
Had to fix a leaking tire on the PS front, and noticed that the lever on the caliper is forward about a 1/2" from where it should be, cable end is not in it's "normal" position on the lever, sticking out past the lever.
Tried to convince the lever to return to home, but it won't budge. Any ideas on a quick fix, other than swap out caliper. I've tore one of these apart, (on the '86), and don't ever want to do that again, total PITA!!!!
It will still go down the road, but not for to long, as the brake will get hot. So it's not totally locked up, just "on", enough you can feel a slight pulling in the steering wheel. Good thing I only live a 1/2 mile from work.
Any help, thoughts, ideas will be greatly appreciated.
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 08 August 2004 - 09:15 AM
disconnect the cable from the caliper. If he lever arm on the caliper dose not return to the normal position, you'll have to fix or replace the caliper. If it dose go back to normal, you need a new e-brake cable
#3 84Scoobaroo
84Scoobaroo
    USMB is life!
  • 171 posts
  • Puyallup
Posted 08 August 2004 - 10:43 AM
I had the same problem, only with both calipers. When i finally came to a stop smoke poured out of both wheelwells and the brakes wouldnt budge. Unhooked the Parking brake cables from the calipers and became a member of the 1st gear club, and still am. :D
#4 subyrally
subyrally
    Trust your Turbo-Lust
  • 2,905 posts
  • frederick, md
Posted 08 August 2004 - 01:34 PM
i had a very simular thing happen on my rx, i traced it to the hill holder. my hh wasnt connected, so that if anyone touched the valve on it, it would lock up the front right brake untill i went in there and turned it.
#5 TomRhere
TomRhere
  • 4,600 posts
Posted 09 August 2004 - 02:17 AM
The '84 is an Auto, so no HH. Wish it were that easy though. Had to use the BRAT to go to work yesterday, brake was really dragging after the 2nd stop. Did maybe 10mph, floored. Not good!! Drove home okay, but I did my best not to touch the brake pedal.
Pulled the knuckles out of the '82 to swap in to the '84. No problems there. Did the PS 1st on the '84. Man, what a pain. Everything fought me, both removing old, and installing the "new". But I whooped it. Still need to do DS, but it can wait a day or two. Atleast I have brakes that release now.
What ever the problem is/was, it's in the caliper itself. Like I said in the 1st post, I've tore one of these things apart and put it back together. Total PITA!! Won't ever do that again. Anyways, the E-brake lever on the caliper is stuck, solid! Tried to wedge the caliper off, hoping I could salvage the pads. No go. Lots of good meat still on those pads, would like to save them, but it don't look good at the moment. Will bring bigger perswader(sp?) home from work today, and try it again.
Still got the touch on swapping calipers out though. Did it with out having to bleed the system. Learned that little trick years ago, and can still do it. Gotta love that.
