Redline ATF
6 replies to this topic
#1 charlierh2
charlierh2
    USMB is life!
  • 168 posts
  • Minneapolis, MN
Posted 27 September 2004 - 10:32 PM
Ive heard all about what Redline MT can do... so lets stick to ATF here.
1997 legacy 110,000k AT (obviously). it has always shifted a little hard and went for a long peroid of time with no ATF change, one done since then. i was wondering if anyone has any expierience with the ATF products vs there MT's? its coming into winter so with sub zero starts and all what can i expect as far as smoothing out shifts.
thanx very much Charlie
#2 Adnan
Adnan
    USMB Regular
  • PipPipPip
  • 117 posts
  • Fremont
Posted 27 September 2004 - 11:08 PM
Hi,
While I haven't used it in a Subaru, I have used Redline D4ATF in another car, in a manual gearbox. It cured a perpetually notchy shifter and quieted things down noticeably.
Others I know who have used it an automatic (non-Subaru) also have been very pleased with it.
Regards,
Adnan
#3 shortlid
shortlid
    Subaru Nutcase
  • 610 posts
  • Derry, New Hamphire
Posted 28 September 2004 - 08:17 AM
I flushed and filled, changed screen and gasket on my '97 Legacy L Wagon EJ22, with 4EAT! I put AAMCO semi-syn. ATF in it. I belive it shifts firmer now but more predicatable!! It also goes ALLOT longer with out geting dark! It was only $2.99 a qt. at AutoZone.
Joel
thanx very much Charlie[/QUOTE]
#4 RodA2003
RodA2003
    USMB Regular
  • PipPipPip
  • 32 posts
  • CA, USA
Posted 28 September 2004 - 04:58 PM
What is the best way of flushing the AT? Another post suggested removing the return line from the ATF radiator (top hose?) and runiing the engine for a short time.
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 28 September 2004 - 06:24 PM
I ran the Redline D4 ATF for a little while. I can't say it made my tranny any better, but it probably didn't break down as easily. It's a shame because I probably got less then 8,000 miles out of that fluid before I did a tranny swap.
#6 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 28 September 2004 - 06:38 PM
Like Adnan I run it in my BMW manual.
#7 shortlid
shortlid
    Subaru Nutcase
  • 610 posts
Posted 29 September 2004 - 08:50 AM
There was HUGE thread on the old Ultimate Subaru server on the process of removing the cooler lines and flushing the tranny. But, if you keep on top of the fluid changes every 30K, or the old fluid does not look that bad, you should get away without it.
Joel
