Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
spark plugs....Q.
#1
Posted 10 December 2004 - 11:08 AM
how much should be the spark plugs gap? in mm....7mm , 8mm or 9mm or 14mm?
the car is subaru leone 160cc year 1993.
in www.sparkplugs.com the gap it's 14mm???!!!
so how much it should be and if i put bigger gap or smaller gap, what will haphand?
what is the best for better performance?
thank you all for your fast answer.
moshe.
#2
Posted 10 December 2004 - 12:55 PM
Your's will probably be a little different than mine since I have an '86 EA82, but my gap is 0.040 inches which is 1.02 mm.
I think you might mean 0.7, 0.8, 0.9 or 1.4mm.
Beyond that I'm, not sure exactly what gap you are supposed to have.
#3
Posted 11 December 2004 - 02:57 AM
hiYou might want to check for a decimal point in there...
yes, i was wrong, I mean 0.7, 0.8, 0.9 or 1.4mm.
it's imazing because no one knows for 100% what the sparkplugs gap should be.
maby someone can help me?
i've been told that for best performance i need to make it 0.7mm, is it true?
what will make a small or bigger gap ?
the car is leone 1600cc year 1993 with carb.
thank you all.
moshe.
#4
Posted 11 December 2004 - 04:50 AM
#5
Posted 11 December 2004 - 09:05 AM
It's a 1600cc as in the EA71 right? If it is the gap should be 1.0-1.1mm
hi
it's EA82.
thank you.
#6
Posted 11 December 2004 - 09:12 AM
#7
Posted 11 December 2004 - 01:12 PM
why everyone in every shop tells me or 0.7mm or 0.9mm? from where they get their information?
moshe.
#8
Posted 11 December 2004 - 01:33 PM
there's your answer already
#9
Posted 11 December 2004 - 07:12 PM
you do ask a lot of questions though:-p
#10
Posted 11 December 2004 - 07:41 PM
But it wouldn't hurt you, Moshe, to buy a repair manual.
#11
Posted 11 December 2004 - 09:45 PM
hi
moshe.
Hey, everyone here is giving you the information from US market repair manuals including the factory manuals from subaru. Oh if you have an EA82 then it's a 1800cc engine and it also has the same 1.0-1.1mm plug gap as I mentioned earlier.
#12
Posted 12 December 2004 - 02:24 AM
i have haynes repair manual of subaru 1600&1800 1980 thru 1994.
in this manual the engine type is OHC engine, so if someone knows what sparkplugs gap is the best for my 1600cc engine, it could help to hear enother opinion.
thank you.
moshe.
and if someone know about enother good book for subaru leone, please write me the name,or the adrees so i can order it.
#13
Posted 12 December 2004 - 02:35 AM
The spark plug gap has more to do with the coil and the spark plug wires than anything else. Wider gaps need higher voltages generated by the coil and conducted by the wires. The higher the voltage, the more energy in the spark, and the greater the chance of successfully igniting the fuel and air mixture.hi.
thank you.
moshe.
If you have a similar ignition system to what is installed on US-version Subarus, then the gap should be similar. The suggested 1.0-1.1mm should be good.
