85 brat with fan problems
7 replies to this topic
#1 guyute1500
guyute1500
    New User
  • Pip
  • 2 posts
  • pennsylvania
Posted 25 August 2003 - 05:30 PM
my electric fan won't turn on. i've checked the fan and it works. i've also tested the harness connecting the fan and it has power but no ground (is this triggered by the thermoswitch?). the ground to the radiator is good, and so is the ground i found screwed under the battery shelf. when i ran a ground straight to the fan the other fan came on. i thought i could have a relay problem but i've been told it doesn't have a fan relay. i guess the only thing left to do is replace the thermoswitch. any suggestions before i go out and order one.
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 25 August 2003 - 05:48 PM
Yes the ground is triggered by the thermo switch
#3 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 25 August 2003 - 06:53 PM
I have blown through like 3 of those dam thermoswitches, So I agree with guyute
#4 North Ursalia
North Ursalia
    aka Captain Morgan
  • 253 posts
  • Margaritaville
Posted 25 August 2003 - 10:41 PM
I replaced one tonight- $5 and 10 minutes later, the fan works again :).
#5 dj72
dj72
    USMB Regular
  • PipPipPip
  • 90 posts
  • canada
Posted 26 August 2003 - 02:39 AM
Cut your wires and run it with new wires and a switch from the fan to the battery then you can turn it on and off when YOU want. dj
#6 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,931 posts
  • Portland
Posted 26 August 2003 - 03:12 AM
Couple things about that - if you do the switch method sugested by "dj72", you should put in a fuse, and a relay would be good so you don't have to use a huge switch and wire. Also - you should wire in the thermoswitch so it can also have a say in when the fan comes on. If the engine isn't allowed to cool itself when IT wants, your asking for trouble. Headgaskets (and worse - cracked heads) are not what your looking for if I had to guess. The temp guages on the dash are next to worthless, as they seem to be inaccurate, or simply fail often.
#7 North Ursalia
North Ursalia
    aka Captain Morgan
  • 253 posts
  • Margaritaville
Posted 26 August 2003 - 08:59 AM
That's exactly what I replaced ;). I'd much rather replace a $5 switch every once in awhile than ghetto rig the fans :D
#8 guyute1500
guyute1500
    New User
  • Pip
  • 2 posts
  • pennsylvania
Posted 26 August 2003 - 03:58 PM
thanks for the info, i tried to put it on a switch till i fixed it the right way but when i wired it up the other fan turned on and would not shut off. not sure why that is but i'll get a new thermoswitch and see what happens. i've had the brat for over 10 years and never had a problem with anything before so hopefully this will fix it for another 10, or till she rusts away. thanks again.
