schspeedster Posted May 8, 2005 Share Posted May 8, 2005 I want one! Have an unused ruggedized aluminum suitcase, and tools scattered around the garage, need some foam rubber that can be cut out, so every tool has its place. Subaru Tool-kit Secrets Letter from SWRT 6 September 2003 With 555 SWRT technicians able to complete a full damper (strut) change in five minutes and a gearbox change in nine, they're among the best in the world. But, they couldn't do it without their trusty Snap-on tools, so we took a look inside a 555 Subaru World Rally Team tool kit to find out just what they use. Each technician has his/her own hand tool kit which is named, and all their tools are individually numbered. Each kit includes 100 items and is worth more than $3,500 US (excluding the case) Each technician works with matching sets of tools, apart from the gearbox, electrical and engine technicians who require extra, specific items. According to Tommi Mäkinen's crew, the tools that are used most are the 19mm impact socket, which is used to remove the wheels during service; the flush pliers, which are used for cutting tie wraps that secure the wiring loom and anything loose in the car; and the 17mm/14mm combination ring spanner, which is used for attaching or removing the components that make up the car's main suspension. The 17mm socket is also vital. Used with the nut gun, the socket is required for suspension changes, gearbox changes, upright changes, traction control arm changes, lateral link changes, sump guard changes, and for changing the front bumper - so it's pretty important! The largest and most expensive item in the toolbox is the torque wrench, which is used to ensure that all the nuts and bolts on the car are set to the correct torque setting (16/ft). The least expensive is the scriber, which is used for marking metal. The most unusual object is the telescopic mirror. Looking more like something owned by a dentist, the extending instrument is used to check for any damage in awkward sections of the car. Each toolbox includes 4 different ratchets, 24 different sockets and 25 different size spanners. And With the exception of the torque wrench, all the team's hand tools are made and supplied by Snap-On, and have a lifetime guarantee. http://www.subaru-msm.com/global/feature/letterSWRT/15.html http://www.swrt.com/440096.html And the Ultimate Subaru Portable Garage Maybe Rally is one reason why most everything on a Subaru seems designed for ease of service. Some of their engineers could have had to actually lie on the ground and use a wrench out in the snow, to get the car back in a rally. http://www.swrt.com/cpimages/671924.jpg http://www.swrt.com/cpimages/678316.jpg Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted May 8, 2005 Share Posted May 8, 2005 Sounds like the tool box I carry in the car at all times. Quote Link to comment Share on other sites More sharing options...
Matty B Posted May 8, 2005 Share Posted May 8, 2005 Carrying and storing tools carefully is a pain. When I was engineering on yachts I came across these brilliant bags called tool packs. This allowed me to easily carry working tools to anywhere on the vessel They do all sorts of configurations for different trades, smaller pouches for sets of things, etc. http://www.toolpak.com/ I have had mine for three years now, all the zips are good, it fits perfectly behind a Brumby seat, holds everything and is actually comfortable to carry or wear. The seperations for tools allow you to make sure they are all there at the end of a task. I have checked it through airlines and it has survived just fine; after putting black cable ties through all the zips. The airline staff nearly s..t themselves when they x-ray it or try to pick it up (its 26kg full) It was about $130 US, whole heartedly endorsed by ME Orroo _________________ Quote Link to comment Share on other sites More sharing options...
avk Posted May 8, 2005 Share Posted May 8, 2005 With 555 SWRT technicians able to complete a full damper (strut) change in five minutes and a gearbox change in nine... With 555 people, sure, why not? Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted May 8, 2005 Share Posted May 8, 2005 With 555 people, sure, why not?You are joking right? You do know the 555 is a sponsor for the SWRT (Subaru World Rally Team), right? 555 is a tobacco company. Quote Link to comment Share on other sites More sharing options...
gravelRX Posted May 8, 2005 Share Posted May 8, 2005 Sarcasm is evidently dead in the language of type. The dry get misunderstood, obvious get insulting and the obtuse is lost. Time for a clarifying smiley. Jay I don't like the bags because they seem to get dirty too fast. The metal boxes are hard on interiors. I like the plastic boxes but haven't found any that I like. Quote Link to comment Share on other sites More sharing options...
frag Posted May 8, 2005 Share Posted May 8, 2005 You are joking right? You do know the 555 is a sponsor for the SWRT (Subaru World Rally Team), right? 555 is a tobacco company. I knew it! Replacing struts that fast is abnormal and will give you cancer. :) Quote Link to comment Share on other sites More sharing options...
