hatch4x4 Posted September 25, 2003 Share Posted September 25, 2003 I'm trying to take apart a front axle so I can use just the stub that holds the wheel on but I can't figure out how to get the damn thing apart. Any help? -- Jeff Quote Link to comment Share on other sites More sharing options...
TomRhere Posted September 25, 2003 Share Posted September 25, 2003 If memory serves me correctly, the inner joint is held onto the shaft by a circlip, it will pop-off with a strike from a hammer and punch. The outer joint is held on with a external snap-ring, you have to disassemble the joint itself to get to the snap-ring, that's a real PITA!!!! I prefer to just beat the thing off of the axle, it was junk anyway, right?! Put the axle on the floor with joint at it's most extreme angle, then whack it with the hammer. The inner cage should break in 2-3 blows. Just be mindfull of where your ankle and shins are located when doing this, could be painfull...... Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 25, 2003 Share Posted September 25, 2003 the haynes manual will say the outer half of the axle is non serviceable. i couldnt get it apart. the way tom describe you will have to break it to get it apart! but if its just an axle stub to hold a wheel on, whats the hurt in that? Quote Link to comment Share on other sites More sharing options...
hatch4x4 Posted September 25, 2003 Author Share Posted September 25, 2003 Thanks Tom, I laid a shop towel over it to control the blast area and it worked great. I did however manage to get a glob of axle grease in my eye from one of the hammer blows. This was with a shop towel over it, so for anyone else attempting this, wear safety glasses!! It did wash out safely although I was a little freaked out at the time. -- Jeff Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 25, 2003 Share Posted September 25, 2003 axle grease in the eye! LOL GD Quote Link to comment Share on other sites More sharing options...
TomRhere Posted September 26, 2003 Share Posted September 26, 2003 Getting stuff in your eye sucks, even if it is just grease. I have to wear glasses just to be able to see, so I don't even think of needing safety glasses. One should always wear eye protection when working on the rides. On another note...Yes, the outer joint is called none servicable, but it can be disassembled. It's just a major PITA to do so. I have rebuilt them in the past, but don't reccommend it to anyone. Major, Total PITA...... Quote Link to comment Share on other sites More sharing options...
