line of oil?
7 replies to this topic
#1 4x4moose
4x4moose
    Eat, Live, Breath Subaru
  • 285 posts
  • Wenatchee the snatch
Posted 25 October 2005 - 06:10 PM
what would cause a staight line of oil to appear on the underside of my hood? oil pump gasket or oil pan gasket. i have reaplace both gaskets(oil pan 2x)
#2 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 25 October 2005 - 07:32 PM
Which way does the oil run, left/right or front/rear. Where is it front. rear , left or right side
nipper
#3 Frank B
Frank B
    Subaru Master
  • 2,226 posts
  • VA
Posted 25 October 2005 - 09:00 PM
Sounds like oil is being flung by one of the belts. Do you have A/C? when the front shaft seal goes out on a compressor, it (Ester or Pag oil)will be flung like that.
#4 zyewdall
zyewdall
    Subaru Master
  • 2,136 posts
  • Ward, CO
Posted 26 October 2005 - 10:01 AM
Yeah, is the oil right above the belt in the front, going from side to side? Could also be if you are leaking PS fluid onto the belt, or the oil filter is leaking onto the belt a little.
If it's going from front to back on the passenger side, it could be the inner CV joint throwing grease, if the boot is ripped. But this looks lumpier than oil. And you'd smell it burning off the cat too.
#5 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 26 October 2005 - 03:24 PM
if this is on your hatch it could be the main front seal. When mine was leaking on my 81 it would throw up some oil. Try to find out what pully the oil is comming from.
center pully=main seal (oil pump is below so oil shouldn't leak up)
AC pully=AC might be leaking
Power steering=power steering leak?
Did you go through any really big puddles? That would throw all sorts of stuff up.
#6 4x4moose
4x4moose
  • 285 posts
Posted 26 October 2005 - 07:19 PM
yes its in my hatch, yes it gose left to right. ac belt is off. took it off cause running the ac made the car run to hot for my comfort. its not the cv boot cause they both blew on my way back from tacome this summber, put out alot of smoke when it hit the hot cat. its on the left side right above the ac comprsser. oh and no power steering.
#7 jeffroid
jeffroid
    USMB is life!
  • 213 posts
  • Seattle area
Posted 26 October 2005 - 09:30 PM
Same thing happened to me. This was years ago before I even knew about USMB. Heck, it was probably before Al Gore invented the internet.
It was the front main seal. Cheap to buy, and easy to replace.
#8 4x4moose
4x4moose
  • 285 posts
Posted 26 October 2005 - 10:05 PM
could this leak be causeing me to get lifter noise do to lowered oil psi. the wire broke off of me sending unit for my oil pressure, so i don't know how low my oil pressure maybe.
