Weird Stalling Issue?
7 replies to this topic
#1 Steveman09
    Subaru Fanatic!
  • 420 posts
  • Portland
Posted 12 November 2005 - 02:22 AM
Ok I have had this problem for a long time even before the E-Manage Project.
What happens is, if its cold and I start it up, it runs normal, but if I dont let it fully warm up before getting into the boost and taking off, after I let off it will mis-fire and die, then when trying to restart it has NO COMPRESSION (fuel flooded) I have to hold the throttle to the floor and crank on it for about 30seconds or so then it finally will fire back up and clear out.
What gives?
Anyone else had this problem?
I usually allways let it warm up but when I'm in a hurry and need to pull out in traffic when its cold, its annoying and I know the MPFI should figure out that it doesnt need all the fuel its dumping to keep it running.
If I dont get into the boost its fine and has no problems.
#2 Steveman09
    Subaru Fanatic!
  • 420 posts
  • Portland
Posted 12 November 2005 - 10:25 PM
#3 WJM
  • 7,828 posts
Posted 12 November 2005 - 11:12 PM
check theecu coolant temp sensor and connections. I imagine that could be something....also, might clean the MAF with high power brake cleaner....and check all electrical connections underhood to make sure all connections are clean, positive and secure.
#4 Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 12 November 2005 - 11:57 PM
My SPFI engine had similar symptoms this last summer. I think I had it tracked down to the coolant temp sensor like WJM said. Never had time to change it before I swapped in the EJ22, but I'm pretty sure that's what the problem was.
#5 86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 13 November 2005 - 07:49 AM
my 88 dl had the same problem and it was the coolant temp ,auto zone has them i think a nissan 200 ?? is the same sensor + alot cheaper than the dealer ,miles fox knows ,
#6 keltik
    Clearly an idiot
  • 578 posts
  • New Zealand
Posted 20 February 2006 - 06:03 PM
We had exactly the same problems on our 86' XT Turbo. It ended up being a combination of waaaaaay too much oil in the sump and a nakkered temperature sensor.
Check that oil! id love to know whats going wrong with yours...
#7 Steveman09
    Subaru Fanatic!
  • 420 posts
  • Portland
Posted 20 February 2006 - 08:46 PM
This issue was resolved, it was the fuel injectors.
#8 mbrickell
    USMB is life!
  • 189 posts
  • Kansas City
Posted 20 February 2006 - 10:04 PM
giveaway sounds like the cold issue. temp sensor of some kind. something is failing to tell the engine that it is indeed cold, it sounds like.
