2005 Legacy 2.5i cruise control shuts off
11 replies to this topic
#1 banny
banny
    New User
  • Pip
  • 1 posts
  • College Park
Posted 06 February 2006 - 04:02 PM
I have a 2005 Subaru Legacy 2.5i, 5-speed manual transmission. When I use cruise control, the cruise control will shut off sometimes. When I say "it shuts off", I mean it no longer keeps the speed I set it at and gas pedal is no longer depressed, but the "cruise" light is still on. So it's kind of like when you're in Cruise Control and you tap the brake, even though I didn't.
At first, I thought it was happening only when the engine exceeded 3k RPM but, but it seems it happens at slower speeds as well. Anyone else experience this problem?
Thanks.
#2 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,805 posts
  • Akron PA
Posted 06 February 2006 - 05:10 PM
the first thing I would check if I was to work on it would be the brake (and also in this case clutch) switch. Maybe the tolerance is set too close and a bump in the road is enough to trip the switch. See if it happens when you hit bumps. Been down this road once in an 85 blazer years ago.
Otherwise...you got warranty...let them figure it out. :D
Matt
#3 hooziewhatsit
hooziewhatsit
    I fix old cars
  • 1,333 posts
  • Klamath Falls
Posted 06 February 2006 - 06:25 PM
try searching at www.legacygt.com I know they have a similar problem listed over there.
#4 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 07 February 2006 - 01:42 AM
Pulling the CC stalk toward you will cancel the setting, Maybe you are knocking it with your knee??
My 2006 Forester lights up the "Cruise" in the dash but also has a "Set" light that comes on when the computer has taken charge.
#5 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 07 February 2006 - 01:59 AM
Thanks.
is there any pattern to it shutting off? Under any specific conditions?
nipper
#6 Legacy04
Legacy04
    New User
  • PipPip
  • 19 posts
  • Boston
Posted 08 February 2006 - 08:48 AM
I just noticed the same thing on my 04 2.5. Seems to shut off when going up a very slight incline. Light stays lit, gas stops though. I think it's under warranty until 36K.
#7 Legacy04
Legacy04
    New User
  • PipPip
  • 19 posts
  • Boston
Posted 08 February 2006 - 08:55 AM
Just spoke with the stealership & there was a recall on the unit.
#8 Juan
Juan
    USMB is life!
  • 196 posts
Posted 09 February 2006 - 04:33 AM
[quote name='banny'] When I say "it shuts off", I mean it no longer keeps the speed I set it at and gas pedal is no longer depressed, QUOTE]
How can you tell if the gas pedal is depressed?
Juan
#9 rcoaster
rcoaster
    H6 Power!
  • 502 posts
  • Rochester, NY
Posted 09 February 2006 - 06:09 AM
Juan
Yeah, I was wondering too because the 2005's are "fly by wire" systems. Your gas pedal doesn't have the throttle cable but a potentiometer attached to it which in turn, controls a servomotor on the throttle plate. You don't have the feedback with cable actuated systems. My 2004's crusie control is a fly by wire system, but still uses the actuator cables, so I do get the feedback.
#10 Legacy04
Legacy04
    New User
  • PipPip
  • 19 posts
  • Boston
Posted 09 February 2006 - 09:00 AM
Dropped off car last eve, and stealer called me this AM saying there was NO recall, but it will be fixed under warranty.
#11 Zephyr
Zephyr
    USMB is life!
  • 127 posts
  • Kansas City, Kansas USA
Posted 09 February 2006 - 10:10 AM
software update?
#12 Legacy04
Legacy04
    New User
  • PipPip
  • 19 posts
  • Boston
Posted 09 March 2006 - 09:54 PM
New computer so they say.
