TheSubaruJunkie Posted October 14, 2003 Share Posted October 14, 2003 Put the final coat on, touched up some stuff, coated the mounting brackets and mounted 2 more sets of lights up front. Then mounted it to the wagon. Looks sweet! Now i need to get the wagon running again so i can show it off 10,000 thanks goes to Tony. More pix here: http://usmb.net/gallery/albuo19 -Brian Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 14, 2003 Share Posted October 14, 2003 Very nice. If I didn't have a rack already, I would seriously consider getting one of those. Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted October 14, 2003 Share Posted October 14, 2003 The car's muddy and the rack is clean? That ain't right? Fix this soon! (And I don't mean wash the car) Great choice in lights ($14 well spent) Glenn, 82 Hatch, transforming.......:temper: 01 Forester, jealous.........:madder: Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 14, 2003 Author Share Posted October 14, 2003 $16 for the front 4, $8 for the back 2 lights. -Brian Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 14, 2003 Share Posted October 14, 2003 How did you route the light wiring into the car? Mine kind of sucks, in that I just slit the window gasket to put the wires through and then sealed it with silicone, and it leaks. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 15, 2003 Author Share Posted October 15, 2003 Havent gotten that far yet, I'll probably string it in through the rear drivers side window, and then run it down the B pillar to the switchboard which will be mounted between my seats. -Brian Quote Link to comment Share on other sites More sharing options...
electryc_monk Posted October 15, 2003 Share Posted October 15, 2003 ...That you consider a rear route for wiring it up. Seeing as how I use the trysty ole CB antenna cable out the rear tailgate and thats just it.... the cable dips between the top of the gate and the roof near the hinge. then it runs down along the outside of the seal and at the bump above the tail light section it crosses over the rubber seal "trim" and ducks under the plastic body molding and then it runs out below the plastic trim under the carpeting all the way to the fromt dash. By way of the passenger side seat lower hinge point and then under the seat and then you could run it along the door rail right at the edge of the carpeting and not have to remove the seats just that plastic door fasing plate(those plastic screws that hold it down). too much effort for runing a main high gauge single wire to the rear tail light area and then a couple relays from there to the lights up on top? too much wiring? That way its clean and outta site though. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 15, 2003 Author Share Posted October 15, 2003 Too much wiring, and take a close look at my wagon. its not clean Im not worried about alittle wire running between the rack and the roof. -Brian Quote Link to comment Share on other sites More sharing options...
electryc_monk Posted October 15, 2003 Share Posted October 15, 2003 "clean" ment nothing that could be "accidentally" pulled out by a hand hunting for a "jesus-grip". given the mud slingin' its done that concept of "Clean" wasn't a consideration. (shrug) but anywho.... it's just an idea. All else , you could do the "cop car stunt" drill a hole in the roof centermast, clean it our (deburr it) sealant the surface, stick a grommet over the sealant, and then run the wire thru the grommet and then coat the wires in sealant just before your "set" and flush" then pull them in and its plugged up. Then all you have to do is run a few switches at the rearview mirror and then a couple hot wires up the front window frame rail and your in business! (piggy back the maplight wires. ya know?) Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 15, 2003 Author Share Posted October 15, 2003 No map lights on a EA81. Naw, i will run a single hot wire to a post strip that will support all my accessories. The light wiring (only 3 wires) will run in from the rear drivers side window, and be tucked into the b-pillar. Then I will run the cable to the switches between the seats. K.I.S.S. No need to drill holes, or run 30' of cable. Besides, ANYBODY who sticks their hand outside of the car to grab ahold of something will be banned from going off-road in my car again. The last thing i need to do is drive someone to the hospital cause their hand was cut off when my car rolled ontop of it. Plus, there are plenty of "MY GOD BRIAN! WATCH OUT!" handles all over the inside of my car. -Brian Quote Link to comment Share on other sites More sharing options...
electryc_monk Posted October 15, 2003 Share Posted October 15, 2003 LOL my version was the "Jesus-grip" or some call it the "Oh$*** handle" you call it: Plus, there are plenty of "MY GOD BRIAN! WATCH OUT!" handles all over the inside of my car. -Brian Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 15, 2003 Author Share Posted October 15, 2003 Yeah, i call them oh-sh!t handles as well. But most the time no one ever sais that in my car. Its always something like "are you sure you wanna do th.... OH MY GOD!!!" -Brian Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 15, 2003 Share Posted October 15, 2003 My favorite passenger expression while grabbing handles is, "WE'RE GONNA DIE!" Which is often preceeded by my second favorite, "Don't you think you're going a little too fast?" Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted October 15, 2003 Share Posted October 15, 2003 Brian, You need one of those bumper/dashboard stickers that says; "Warning, this vehicle not recommended for small children, heart patients or pregnent women." You gave them fair warning......... Glenn, 82 Hatch, will have sticker......handles and wires inside the tube frame:temper: 01 Forester, won't have sticker. Quote Link to comment Share on other sites More sharing options...
