a few questions
11 replies to this topic
#1 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 19 September 2006 - 04:59 PM
on a 90 legacy ls. the power light flashes me a duty solonoid b code. the car drives and shifts great. the car has new brakes and rotors but it shakes when the brakes are put on. i can feel the vibration in the pedal also. it does not pull to one side. it has abs.
#2 nipper
nipper
    Semi Elite Master of the
  • 18,191 posts
  • Long Island NY
Posted 19 September 2006 - 05:03 PM
i thnk B is the lock up torque converter, not sure.Are your rotors warped or out of round from having the lug nuts overtorqued? Wheel bearings?
nipper
#3 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 19 September 2006 - 05:18 PM
new rotors were put on and their was no change. it feels like the whole car is doing it not just one wheel. the guy we got it from said something about checking the proportioning valve. it feels like it takes a little more force on the pedal to stop it than normal
#4 nipper
nipper
  • 18,191 posts
  • Long Island NY
Posted 19 September 2006 - 05:22 PM
if they over tighten the lug nuts on the wheels they can warp the rotors.
Inspect the tires for broken belts
never go back to the guy that said purportioning valve.
who did the brakes?
What kind of pads were put in
Could be improperly installed pads, loose caliper, there is a list,,
#5 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 19 September 2006 - 05:28 PM
i guess the car started doing it, then he replaced the pads and rotors to see if that was the problem, but their was no change. could the abs system cause this.
#6 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 19 September 2006 - 05:30 PM
in fact, overtightening lugs is the only way to get warped rotors assuming they were straight in the first place.
How long were they on and were they bedded in properly? I kind of doubt the problem is thickness variation so maybe a caliper bolt is loose or something.
It could even be an alignment or wheel balance problem or something loose or damaged/worn out in the suspension/steering.
#7 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 19 September 2006 - 05:36 PM
if it was wheel balance wouldn't the car shake even without the brakes on? the car rides smooth and drives strait until the brakes are used. if it was a loose bolt i would think that it would have been tightened when the new pads were put on.
#8 nipper
nipper
  • 18,191 posts
  • Long Island NY
Posted 19 September 2006 - 05:44 PM
Ok here is a list
Wheel bearings
seized/bad cv joint
bent wheel
broken belt in a tire
wheel balance (can happen at any specific speed but will always repeat)
bad suspension component
bad tie rods
loose calipers
warped rotors (they can warp real fast if improperly installed or el cheapos)
ABS would not make the car shake, just the brake pedal.
APply the parking brake while moving this will maybe help tell if it is front or rear.
Does it do it in reverse, or any change in reverse
Turning any effect on it?
nipper
#9 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 19 September 2006 - 05:45 PM
sometimes mechanics forget to tighten things. I got an alignment awhile ago and had kind of a strange loose feeling on right corners. When I pulled the left front wheel off to take a look I found the bolt that attaches the strut to the knuckle was loose. Hopefully mentioning that will get me a free alignment after I install new balljoints and camber bolts next weekend.
It is probably something with the caliper though. It's probably a good idea to take it back and have them make sure everything is tight, the slide pins are in good shape, and the rotors are straight.
If you brake hard does abs kick in and work properly?
#10 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 19 September 2006 - 06:10 PM
nipper: if one of the things you listed was the problem, would the car still drive normal. the car feels perfectly normal otherwise.
if it was one of the calipers wouldn't it pull the car to one side.
to my it feels like the whole brake system is vibrating not just one wheel.
#11 nipper
nipper
  • 18,191 posts
  • Long Island NY
Posted 19 September 2006 - 07:26 PM
The brake calipers are held on by one bolt, and another it swings on. If one is loose you will get chatter.
Rule out the ABS, pull the fuse.
If you rember your science lasses, you should (i hope) know what frequency it and vibrations are. a vibration can occur at specific frquencies, but not others, frequency being car speed.
Lets rule out the abs first.
Now how many miles on this. The B solenoid can be keeping the torque converter locked up longer then it should be when breaking.
Try braking the car in Low, Drive2 Drive3 and see what happens.
nipper
#12 pamike
pamike
    Subaru Fanatic!
  • 383 posts
  • Jersey Shore, PA
Posted 20 September 2006 - 05:07 PM
it has 160,000 miles. it does it regardless of speed. i was going like 5 mph and the car shook. it takes more pedal pressure than normal to stop it, compared to other subaru's i've drove. i will have to try pulling the abs fuse.
