ea82 no heat
Submech, the dash ventilation system is controlled via vacuum servos. These are selected with the control push buttons
Under the hood behind the pass side strut tower is a white plastic cannister. This is the vacuum reservoir. It has a check valve incorporated into it.
Find out if it is indeed is storing vacuum (broken/disconneted line to it?) Then follow the line from it to the dash control panel.
Sounds like somewhere you are loosing the vacuum to control the system.
If you have already ascertained there is vacuum present at the control panel please post this fact.
Hope this helps.
Assuming you have an American not Canadian model
as per the FSM
connection 1 goes to the servo labled as "B" sits at app. a 45 degree angle on the side of the hivac unit (windscreen heat)
connection 2 goes to the servo marked as "A" sits horizontal on the side of the unit (dash/floor vents)
connection 3 goes to the servo marked as "D" and is on top of the unit. (fresh air /recir)
hope this helps
You say
"servos work"
I will assume you applied vacuum via a Mighty Vac or similar to establish this fact.
I do not know where you are getting your line numbers from?
Please reread my original post for the answer to your last question.
You said
"I have vac. to the supply line that runs through the firewall"
So I do not understand this last question, good luck, Skipout
turns out it was ngr rgd -- trying to fix the problem
How can I tell if the controller is bad?
Am I supposed to hear a constant sucking?
:cornfuzz: :cornfuzz:
What's line 4 for? Where does the supply main line "properly" connect to the engine? How can I tell if the controller is bad? Where can I get a diagram? All lines are numbered on the soft rubber, the controller, and the connectors.:confused: :confused:
