Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Driver's side internal lock does not lock the other door locks.
#1
Posted 13 November 2006 - 11:49 PM
The exterior door lock on the driver's side locks and unlocks the other door locks just fine.
However, the interior door lock doesn't work the other locks.
Any ideas on what is wrong and how to fix it?
#2
Posted 13 November 2006 - 11:51 PM
The key is supposed to lock/unlock the other doors? Hm...
My guess would be that something is worn. The interior panel comes off easily, and you can check out the mechanism.
-=Russ=-
#3
Posted 13 November 2006 - 11:54 PM
#4
Posted 13 November 2006 - 11:55 PM
#5
Posted 14 November 2006 - 12:04 AM
I'll give it a whirl. I'll let you know how it goes.
Thanks.
#6
Posted 14 November 2006 - 12:09 AM
#7
Posted 14 November 2006 - 12:26 AM
#8
Posted 14 November 2006 - 12:30 AM
mine did this too, just ended up being the switch that controlled the locks. I replaced it with one from the JY and worked great after that.
Hmm, so perhaps a switch replacement then. I can live with that, thanks.
#9
Posted 14 November 2006 - 12:32 AM
Mile also does this, or does not depending on how you look at it. I think the mechanisim is broke on mine, it just kinda flops around with no resistance on it. I'm more worried about the window switch bank, right rear goes down with drivers control, but you have to use the door switch to roll it back up.
Mine seems to have resistance, a bit more than it probably should in fact. Hopefully that means GD is on the right track. If it is broke though, I can live with finding a replacement switch.
#10
Posted 14 November 2006 - 12:35 AM
#11
Posted 14 November 2006 - 01:02 AM
I recently dealt with this problem on a 90 legacy and I am pretty sure that the basics are the same. There is a link rod running from the lock cylinder down to the lock mechanism and switch, and another rod running from the interior door handle to the mechanism/switch. The door handle's rod is probably bent a little wrong, so that it can activate the locking mechanism but not the switch contacts.
That sounds like a likely possibility. I will check it out while I am in there coating everything with white lithium.
#12
Posted 14 November 2006 - 01:22 AM
#13
Posted 15 November 2006 - 05:13 AM
As a test, earlier today I fiddled with the inner lock a bit and given the slightly higher than normal resistance on the switch I decided to close it with a bit of gusto instead of carefully closing it.
All the internal locks snapped shut.
I think when I get inside the door this weekend and clean it all out and lube the bejeezus out of everything that this will clear my lock issues up.
Thanks again for the good info and ideas, I will post back with and update after I have a chance to try this.
#14
Posted 15 November 2006 - 06:17 AM
#15
Posted 16 November 2006 - 09:11 PM
once it started to become apparent that you probalb yjust needed to press harder, i realized I kinda have the same problem, I think.. and to me, it has always felt like there was a good chance one of the long metal arms was a bit bent, or fatigued.. or something worn, in some sense.. more than a simple lube. So, my point it, you may need to swap something to really "fix" this, even if lubing it up makes it OK. It may just be OK for now, you know? just food for thought. Good luck, though.. I will be paying attention. I haven't bothered because MY car isnt anywhere near as bad as yours, yet, and the passenger's side is worse than drivers..
Yeah, I was thinking I would inspect everything carefully. I have some metalworking skill so if it is a bent rod or somesuch I can probably fix it or make another.
Jason
