Electrical Problem
4 replies to this topic
#1 soobyfan
soobyfan
    USMB Regular
  • PipPipPip
  • 45 posts
  • Beaverton, OR
Posted 05 December 2006 - 10:56 PM
I have a '96 OBW, 2.2L, 5SP MT.
My symptoms are: The charge light came on, the brake light came on. I got the car home, charged the battery with an external charger, then started it back up to do some checks with a volt meter. I read 12.0V with the engine running and 12.4V with it turned off. This sure looks like an alternator that is dead, are there any other things that could cause this? I also checked the lugs at the battery, cleaned and tightened, so I am getting reasonably good contact right at the battery.
Thanks in advance.
#2 brus brother
brus brother
    Subaru Master
  • 2,226 posts
  • Connecticut
Posted 06 December 2006 - 03:29 AM
Alternator.
#3 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 06 December 2006 - 10:07 AM
What he said. No need to do any further work, its the Alt. When the alt goes bad, it lights up the brake light, and possibly the alt light. When voltage gets really low it wil light up the ABS (what at this point is called the ABout to Stall light).
nipper
#4 RallyKeith
RallyKeith
    Got Subaru(s)?
  • 1,500 posts
  • Reading, Pa
Posted 06 December 2006 - 12:45 PM
nipper
Yeah, my 96 lite up the ABS light when the alternator died. That through me for a loop, but it was in fact just the alternator.
Keith
#5 soobyfan
soobyfan
    USMB Regular
  • PipPipPip
  • 45 posts
  • Beaverton, OR
Posted 06 December 2006 - 02:39 PM
Thanks for all the input. It did turn out to be the alternator.
The light sequence was just as described, first I got the charge light and the brake light, then the abs light, then the check engine light.
FYI, the Haynes manual has a pretty good write up on checking out the charging system.
