Lowering an ea81
28 replies to this topic
#1 86BRATMAN
86BRATMAN
    Elite Master of the Subaru
  • 3,963 posts
  • Tazewell Virginia
Posted 26 March 2007 - 10:09 PM
I know the basic principal. I just don't get how to do the torsion bar adjustment in the back. The bolt adjustment is as low as it will go.
I read in an old thread or two about removing the ends from the tube and repositioning them. But without taking a look and risking breaking something, how does it come apart?
Anybody have any pics of taking the tube apart, or pictures of some lowered?
#2 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 26 March 2007 - 10:21 PM
I would be more interested in fitting a non-torsion bar setup in if I were you. But I guess if it can be set at the right hight and you like the spring rate then it should be alright.
I've pulled a torsion bar out of my brumby before. Not too pull it apart, but to get that adjuster bolt working again. Wasn't hard at all and I didn't even use the manual.
After reading my manual just now it doesn't say whats holding the trailing link to the torsion bar, by the look of it you just have to unbolt the trailing link for the trailing arm and then it pulls out the whole torsion bar. Then you just need to put it back in on a notch clockwise, I tihnk.
#3 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 26 March 2007 - 10:25 PM
I've thought about the spring rate as well, since some said it was too soft a ride. I'm considering ea82 rear struts w/ wrx coilover kit(or something similar) to give some more adjustability.
I'll have to take a look at it tommorow after work. Its late on this side o' the world, :grin:
#4 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 26 March 2007 - 10:33 PM
I know on the gen 1's, there is a bolt on either side of the torsion bar tube that you remove, then pound the torsion bar out from the inside while the car is on stands, then using a jack, position the tire at the desired height (as far as 2 notches on the torsion bar, 3, etc.), pound them back in, reinstall the bolt and put it on the ground. Thats how I lowered the back of my Gen 1 Brat.
#5 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 26 March 2007 - 10:40 PM
I was hoping you would chime in. I knew you'd done it from looking up old posts. But the old pic links are long since dead.
I do remember seeing a single 12mm bolt on each side of the tube now that I think about it...:drunk:
#6 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 26 March 2007 - 10:43 PM
One of those no brainers by the sounds of it. give us pictures once you got that back down..
#7 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 26 March 2007 - 10:57 PM
Well I've got the front lowered already:grin:
The back is sittin slightly low as it is, new shocks that still have the wire bindings on them
Posted Image
Posted Image
Posted Image
Posted Image
Try and overlook the busted foglight. The last time the brat was driven was on my parent's land, it kinda got wedged, and the clutch when to nothing getting it unstuck.
#8 BlueSteel
BlueSteel
    USMB Regular
  • PipPipPip
  • 83 posts
  • Tasmania, Australia
Posted 27 March 2007 - 06:45 PM
yeah all you gotta do is unbolt the 3 17mm's on the trailing arm and the 12mm that is underneath the tube near the end
then just tap the trailing arm out with a hammer
clean up the splines a bit and spray on some wd40 or anything like that to make things much easier
then just position the trailking arm at the height you would like and slide it back in
chuck the 3 17mm's back in and the 12mm at the bottom and youre done
and you have gotta do it oin both sides ;)
i have done this before on a wagon... not really the best solution:confused:
if you go as low as it looks like your front is, then you will basically be riding on the bumpstops in the rear
you can get some extra suspension travel by removiong the bumpstops (they are meant to screw out, but ive never been able to)
a setup similar to the rear of the l series would be the go, stiffen the rear up and have short stroke shocks and you should be laughing
#9 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 27 March 2007 - 06:51 PM
not to hijack but how do you lower the front of an EA81? I would really love to lower mine but mines 2wd. Would that pose a problem?
#10 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 08:26 PM
Asking for more info isn't a hijack in my book:)
For right now, I'm using a cut a set of 2wd springs/struts. I cut about 1 3/4 coils out of each, or was it 2 3/4 coils... I'll look tomorrow. I'm going to be purchasing a coilover kit in the future(five lug swap +xt6 struts, or if this rides like poo, and it probably will)
I removed the springs, and marked them both at the same time so they'd be even. And used my angle grinder with a cutoff wheel, and wear eye goggles or something, as the disc will begin to disintegrate and throw stuff at you.
If you want some pics of the front I can pull it apart this weekend to illustrate.
#11 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 27 March 2007 - 09:28 PM
oh ok the oldschool technique of cutting springs. Thanks for the reply but im worried about the ride quality with that. This is my daily driver and i dont want to jump onto a sidwalk or something if i hit a bump
#12 crazy D
crazy D
    Certified Subaru Nut
  • 898 posts
  • Reno
Posted 27 March 2007 - 09:31 PM
that is one sick looking brat my friend:headbang:
#13 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 09:56 PM
I've had a little experiance with cut springs before. And its not really that bad, people who say it handles like crap probably didn't do it right( heating too much or baking the springs will kill off any spring rate they have)
My last integra w/ cut stock springs handled just as well as my integra before that with aftermarket skunk2 springs.
Low-rider guys have been doing it for years.
#14 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
get a set of 4wd springs and cut those. I believe those are a bit stiffer then the 2wd so if you cut them, the ride quality will be about the same.
So some old posts eh? Check out my '78 Brat back when I lived in Oregon!
Before when I first got it...
Posted Image
After and adding the EA82 steels with some nice 185/70R13 tires...
Posted Image
The last pic is after I removed the bumpers, added on a throaty souding exhaust and before I removed the mudflaps. In this car, there was no such thing as ride quality. I removed the front springs and bumpstops from the front end so it was tucking the 13"s and in the rear, I cranked the torsion bars all the way down and cut half the rear bumpstops off. Handled like it was on rails but was a real bumpy ride. For some reason though, since it had a blown front axle and I rolled around in RWD, the rear diff would posi everytime I would light up the back end. Made it an awesome drift/burnout machine!
#15 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 09:59 PM
Thank you. I've got some pretty good plans for it coming. Its in mid stages of ej swapage right now. And I spent the majority of my budget for finishing it on the down payment for the wifes car, but at least its a subie too:banana:
#16 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 10:03 PM
Posted Image
Posted Image
Awesome man, I was hoping you'd still have pics of that one since the old photo albums were gone:headbang: .
I've got my stock springs too, I just wanted to get an idea of how much to cut using the 2wd's from the parts hatch.
I wanna put the 4wd's on before it goes to the road since they have the height adjusters as well.
Oh and speaking of mud flaps...
Posted Image
Disregard the rusty rockers. i'm back east:mad:
#17 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 27 March 2007 - 10:39 PM
Posted Image
HAHA thats all thats holding the rocker together!:lol:
Sorry I couldn't resist. If you wanna see all the pics I have of my Brat, here's the link... http://rides.webshot...302432023YUcDSD
Its currently undergoing major body restoration down to mediablasting, fixing the rot in the core support from the battery, shaved everything but doorhandles, rear slider, EA81 with s/r 4-speed and tons of other stuff.
#18 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 10:43 PM
Rust is an all too common thing here. Thats why I'm going to weld in stainless wherever it needs it.... I mean, I'm going to make a new brat out of stainless.....
It has literally ben years since I've seen a gen 1 anything on the road within a 3 hour radious of here.
Edit... Be a real lower rider guy and shave the door handles too!!!
#19 P K
P K
    Devil Dog Liaison
  • 1,171 posts
  • Omicron Persei Diego
Posted 27 March 2007 - 10:47 PM
This was sent to me a while back, so I don't have any more info. Enjoy:
Lowered Hatch
r/ PK
#20 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Usually gen 1s around Wyoming are pretty rusted. However, sicne I am from the PNW which is where I got my Brat, its clean compared to a few cars I see around here. It even sat in a junkyard for 15 years!
I think its time for you to move to Subaruland. Its actually more of a region located in the north western portion of our beloved country:-p
#21 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 10:53 PM
Lowered Hatch
r/ PK
I'm in love....
I wouldn't mind a change of scenery. But the family would be missed too much.
Maybe a trip out west with some cash and a gooseneck trailor from work...
Hmmm how many subes will fit on a 26 footer???? Now that is the question.
#22 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 27 March 2007 - 10:55 PM
Oh ok cool. I might end up doing this sometime if i can find someone who has done it before to do it for me. I dont have the tools to cut springs myself. Your brats got a cool stance to it now. And btw i got rust problems in connecticut too :(. I need to get my sedan fixed again as its rusting faster than i can fix it.
#23 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 10:57 PM
Since I'm gonna cut some 4wd springs in the near future...
If you want these I'll send them your way
#24 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 27 March 2007 - 11:06 PM
Are they 2wd springs or 4wd ones? Thanks for the offer. I may just take you up on it
#25 86BRATMAN
86BRATMAN
  • 3,963 posts
  • Tazewell Virginia
Posted 27 March 2007 - 11:11 PM
These are the 2wd's on it right now. I will be making a j/y run friday or saturday weather permitting. If they Have some decent xt6 stuff I'll be getting it anyways, and won't need my 4wd ones. I could mod and send them.
