What does this Relay Control? --Edited-
9 replies to this topic
#1 Goatboy
Goatboy
    USMB is life!
  • 230 posts
  • Portland, OR
Posted 05 December 2003 - 12:49 PM
-Edit-
So what are those two relays by the vac. can. on the pass. side strut tower??
-End Edit-
There are two relays by the vacuum canister that the climate control system uses. Are these also for the climate control? It seems I have lost power to my cliamte control. Fuses all check out fine but all of a sudden none of the climate control settings work. The blower fan doesn't turn on and there is no difference when switching between any of the settings. Defrost Heater Bi-Level AC, none of them do anything. Is this a relay problem?? All help is greatly appreciated.
PS - I noticed this after installing a new car stereo. It is possible that I could have inadvertently knocked something loose in the dash. But wanted to rule out relays before I pulled the stereo back out.
--GoatBoy--
#2 Goatboy
Goatboy
    USMB is life!
  • 230 posts
  • Portland, OR
Posted 05 December 2003 - 02:00 PM
I guess I could just swap them and see if it works again. I have a few spares I picked up at the JY.
--GoatBoy--
#3 moosens
moosens
    Vintage Subathusiast
  • 1,755 posts
  • Bridgeport CT
Posted 05 December 2003 - 02:10 PM
Just did this earlier today!!
Under the driver's side of the dash.Take down the panel.Take the fuse box down but no need to disconnect.Look up,you'll see 4 relays all the same.The heater/fan is the one with the to the left on my '87 wagon.It's the one with the smaller wires,not the thicker black wires.
When you take the relay out you'll see that 2 of the 4 prongs are blueish-shorted out-toast!!!.
Enjoy!!
If you need known good relays I'll be happy to send you one.Email me if you do want one.
#4 Goatboy
Goatboy
    USMB is life!
  • 230 posts
  • Portland, OR
Posted 05 December 2003 - 03:09 PM
I'll check them out and see what they look like. Thanks for the offer. I'll be in touch if need be. All this rain up here in Oregon, its hard to keep you windows from fogging without a defroster.
On another note, does anyone know what those two relays behind the pass. side strut tower are. They are with the vac. can. for the cliamte control.
--GoatBoy--
#5 Goatboy
Goatboy
    USMB is life!
  • 230 posts
  • Portland, OR
Posted 05 December 2003 - 03:48 PM
Bump
#6 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 05 December 2003 - 03:54 PM
GB, the fact that none of the positions work (bilevel defrost ect) is not from a bad relay. You must have disconnected the vacuum feed to the control panel. When the controls are in the off position the blower fan will not run.
Is the vacuum reservoir for the dash control, or vac can, connected properly.
The two relays you ask about are for the AC system, one for the AC compressor the other for the rad fan.
Hope this helps
#7 Goatboy
Goatboy
    USMB is life!
  • 230 posts
  • Portland, OR
Posted 05 December 2003 - 03:55 PM
I did not know that the blower fan will not operate if the vac lines are not connected. They might have came loose. I will check those. Thank You!
--GoatBoy--
#8 moosens
moosens
  • 1,755 posts
  • Bridgeport CT
Posted 06 December 2003 - 12:52 AM
Uhh,like I said,I had the same problem and it was indeed the relay.The prongs were absolutely noticeably blueish and toasted out.Perhaps a short developed somewhere causing the same result.
All I know is that I have HEAT!!! and love it!!
I also NOW have A/C,Def.,BiLevel.
#9 Goatboy
Goatboy
    USMB is life!
  • 230 posts
  • Portland, OR
Posted 06 December 2003 - 01:03 AM
I looked at all four of those relays and none of them had any hint of blue on the prongs.
--GoatBoy--
#10 moosens
moosens
  • 1,755 posts
  • Bridgeport CT
Posted 06 December 2003 - 11:47 AM
Skip seems to be all over this.He's the genious of the operation.All I know is I had the same problem and now I'm loving life.Like he said in your other post,check for power to the blower fan under the glove box first.Good luck.
