Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
1986 subaru dl hatchback Water in oil!! help!
Started by
subaru18
, Jan 12 2008 07:10 PM
7 replies to this topic
#1
Posted 12 January 2008 - 07:10 PM
I have an 86 subaru dl and i just got it and the water pump went out so i removed and drained the oil and it was all milky and had water in it... What could cause this? could it be a head gasket or something worse?
#2
Posted 12 January 2008 - 10:17 PM
First thing we need to know is if you have an EA81 or EA82?
EA81's are pushrod.
EA82's have timing belts.
Which is it?
EA81's are pushrod.
Which is it?
#3
Posted 13 January 2008 - 12:21 AM
Also do you know any history of the car ?
nipper
nipper
#4
Posted 13 January 2008 - 12:57 AM
A shot in the dark, with the minimal information we've got. Possibly it wasn't the water pump at all, and it was a bad headgasket? I might be way ahead of myself here, +1 on more info on the car. What happened that you knew the water pump was bad, motor and mileage?
#5
Posted 13 January 2008 - 12:34 PM
Possibly a freeze plug in the head let loose. That will fill the crankcase with coolant.
But again, a GD said. Are we talking about an EA82 or EA81?
You call it a hatch, but is it actually the "3 door Coupe"?
#6
Posted 13 January 2008 - 01:18 PM
Well it has a timing belt! I bought the car and the lady said it ran when she parked it. The water pump is bad because water was leaking out the bearing in the front...:-\ it dont have a hole lot of miles dont no exact milage. but we poured water into the radaitor and it ran right out the oil pan!!
#7
Posted 13 January 2008 - 01:54 PM
Might have popped some of the freeze plugs out of the heads. Start figureing on a head gasket job and inspect carefully as you go.
Technically your 88 is not a "Hatchback". It's refered to as a "3 Door Coupe". While it *is* a hatch it needs to be distinguished from the EA81 Hatchback, which was still being produced in 88. The EA81's came first, so the Hatchback label was already taken. For clarity here and elsewhere you should start calling it an EA82 3 Door Coupe.
#8
Posted 13 January 2008 - 02:01 PM
And look up all you're parts(except body) for a Wagon. As lot's of parts places have all Subarus of that vintage listed as "1800"s, and often the only distinction is when they ask if it's a 3 door(which they actually mean the hatch, EA81) or a Wagon(EA82)
But all the wagons of that year are EA82. That's what, you need are EA82 parts.
