Transmission Case
4 replies to this topic
#1 pearlm30
pearlm30
    Eat, Live, Breath Subaru
  • 356 posts
  • Tampa, FL/ Bethlehem, PA
Posted 24 August 2008 - 08:53 PM
I found a wrecked 98 Forester at a local junk yard( pick and pull) and I need the 4EAT trany. A friend and I accidently cracked and broke one of the holes that bolted to the engine( with the pin) during removal..
Is this going to affect anything? Is the trany trashed? Pictures are in my photos in the header above .The broken hole is located below the starter.
Any advice?
Thanks
#2 McDave
McDave
    Subaru Fanatic!
  • 477 posts
  • Highland Lakes, Texas
Posted 24 August 2008 - 09:28 PM
Had the donor car been in an accident? If so where was it hit? I'm inclined to believe it was already cracked and just happened to fall apart when you removed the tranny, but then I wasn't there to see what happened.
If the tranny wasn't damaged in a bad accident, it will probably be fine as long as you tap the dowel pin into the engine block, and then if you don't end up with a bunch of up and down play in the tranny once it's mated to the block - before tightening the bolts or TQ. Worth a shot, imo.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 24 August 2008 - 09:37 PM
Those are just alignment pins. Enough of the hole looks to be there to serve the puposes of alignment. They do nothing once the bolts are tightened down.
#4 pearlm30
pearlm30
  • 356 posts
Posted 26 August 2008 - 01:02 AM
The donor was hit in the front, engine and trany was pushed inward about half inch since the trany mount was pushed back a little.
I guess the dowel pin hole broken could be caused by the accident, good to hear it has little or no affect on the installation.
I will keep everyone updated.
Thanks
#5 idosubaru
idosubaru
  • 23,731 posts
  • East Coast
Posted 26 August 2008 - 01:36 AM
i've seen this happen before when removing an engine/trans, i wouldn't worry much about it either if it's just essentially cracked and/or a small piece missing.
