tunered
Everything posted by tunered
transmission fluid is more of a coolant than a lubricant,thin oil carries away more heat[because of faster runoff]than heavy-thick oils.nascar qualify on 0-10 weight,drag racers race with 0 weight oil [consistancy of water] only 25 dollars a quart.so im not really convinced that heavier oil is any better.opinions is like a 0-0-0-0-0-0sbut there has to be something to this thin oils. ed
just my opinion,5-30 makes sense in cold climates,oil flows easier less engine damage at start-up.but hot weather oil--bullcrap--your engine runs the same temperature[or should] whether its 100 degrees outside or 30 degrees outside,so if anybody can explain why the same motor at the same temp needs heavier oil please explain.i understand "loose" engines can benefit from a thicker cushion of oil. but heavy oil will decrease milage whether you know it or not. ed
torque bind?
tunered replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
torqe bind is wgen the rear end binds up,yours sounds like a bad rack. ed -
check the pressure on cold tires[like first thing in the morning before you drive it].pressure will go up about 4 pounds in a 10 mile drive.say they have 32 pounds cold at 80 degrees outside temp,at 40 degrees that same 32 pounds will be about 28 pounds,i think you need to have that one tire checked for a slow leak. hope this helps. ed
drive axle
tunered replied to wtbaker75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
a little bit of heat goes along way. ed
