jimscat
Everything posted by jimscat
Filters?
jimscat replied to derekho55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
whats wrong with fram? -
I took it off the car myself so I know it didnt sit around long. I read through the post legacy, but did not see any where on the amount of oil you used. both the 93 and 95 had little to no oil. I just bought a haynes manual and did not see anything about the oil amounts and it basically said to take it to a ac tech.
I have a 93 legacy wagon 2.2, the clutch on the ac compressor locked up yrs ago and i recently have been given one off a 95. They are the same brand and bolt up identical. The only thing I see is that the 93 is r12 and the 95 is 134. Subaru, parts store, and bone yard all say that it cant be used. Is this true? Thanks Jim
Hey guys, its been awhile since I needed your advice, but here goes. about 4 yrs ago the clutch on the ac pump froze up and knowing it was expensive to fix i just took the belt off. I have a 93 legacy wagon 2.2 with a zextel ac pump. I was recently given a pump (same brand) off a 95 legacy wagon. everywhere i call they tell me that the two yrs are different because the part #'s are different. There is only one difference that i found, one was r-12 and the other is r-134. I currently have it bolted in the car and am waiting for my machanic to get back from vaca to do a leak check. WILL IT WORK? Thanks, Jim
93 gas milage
jimscat replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
thanks guys. With the holidays it looks like it will be after the first of the year before I can get it changed. -
93 gas milage
I read trhough the related posts, I guess I am almost on the money with what everyone seems to be getting. +/- conditions and driving style. Where are the fuel filter(s) located? Thanks everyone. Jim -
93 gas milage
I fogot to mention it is an auto. I have done everything but the oil and no improvements. A little worse now that its cold. Dont have a low fuel light that Iknow of Thanks. -
I did a search and could not find what I was looking for. I have a 93 Legacy wagon 25th edition 2.2 with 141,000 miles. I have never gotten more then 200 miles out of a tank of gas (mostly city driving) exept when I have run a constant 70-75 out on the highway and I can get better then 300. Any ideas on what I should be looking at or replacing? Jim
I can't find the name of the one that has a 3" lift on his. He has many posts on here and has personal pics. I believe he is running 28" on his. Someone who knows will be around.
Ok I found the connectors. They are on the right side of the steering colomn in my car. After running I came up with 11, 21, 32, 34, and 11. My brother (a chevy mech suggested that I do the battery trick to clear the codes, and go for a drive, then check again.) I come up with just 21. The temp sensor. I went through napa and they gave me a brass colored single pole sensor. Is this the correct one or is it the one next to it with the big connector? Thanks
