95 super subbie
Everything posted by 95 super subbie
  1. i going to lift my 95 awd 5 speed legacy sedan i need to know what year range, outback spring and struts that i need to do that. right now i got new copper cobra radial gt raised white letter's 195/75/14 on it now and they digg!!!!!
  2. i stop and asked it went for 1,500$
  3. no it not that one that brat you saw was only on the lot for a couple hours before it was sold
  4. i found a 83 brat 4wd push button, t-tops, factory ac and it has the jump? seats in the back facing backwards the outside of the body is good but the rear fenders in the box is really bad how much is it worth??
  5. i have a 95 legacy sedan that i just hit a deer with i need new headlight fender and hood i got the headlight and fender i want a hood with a hood scoop like the legacy gt or outback hood will those hoods from and outback if i cant find a legacy gt hood, bolt up to my car?
  6. im going to do the charity rally on friday me and my twin brother are skiping school that friday and doing the novice class, and me and my brother won a distance speed timed road rally race at our high school for a person senior project
  7. i been driving with it clicking real bad for a month now and when i try to drive it sounds like the wheel is going to fall of and it shakes really badly and i mean realy badly! only happend today but does it only for about 10-20 sec thens it fine then it did it again about a mile down the raod so i said i stop a get a axle for before i screw something major when i made it home
  8. its 95 awd legacy and the front axle is shot and no one has one untill monday can i pull the front right axle and still drive it till monday without screwing up anything or hurting anthing ??????
  9. i got my skid plate for my 95 legacy off a 91 loyale it was a stock skid plate, better than nothing
  10. after i got the tranny in the check engine light comes on and at the gas station i work at after school i pluged the hand held computer in it it comes up as po505 ''idle control system malfuction" somtimes at a stop sign it will quit when i push the clutch in.. but it idles fine in the moring. when have the thing on the computer that tells what causing the check engine light to come on but nothing for subaru, just gm, dodge, chevy and ford
  11. i live in tioga co, mansfield l
  12. i just put the new tranny in and the back up lights are on in all the gears but not neutral. it will keep the tailgaters away, right now i took the bulbs out. did i get the 2 sensers mixed up? that go on the side of the tranny they look like a lugnut with 2 wires on them
  13. i still havent got the tranny in yet because everything that could go wrong did go wrong first, i droped the throwout bearing when tring to put it together and broke off one of the ear/tab on the bearing so i had to order a new bearing from carquest when it came in i could not find the little spings that hold the throwout bearing to the fork and autozone did not have a thing listed in the computers so i have to stop at the soob dealership today and get some new springs
  14. nice pics of wheelin if you want a another soob to go whellin with im just up in mansfiled, a good spot to do some nice offroading/mudding go to Morris run up in the stripmines its about 50 miles from you, strat
  15. we had to take the motor mount that goes from the back of the engine and connect to the fire wall to let back engine fall back, the hard part was sperating the tranny and engine block its a 5mt tranny and their was no gasket between them i broke my beefist craftmans screwdriver trying to sperate the engine and tranny i ended up using a chisele and hammer the get em apart
  16. i got a 95 awd 5mt leagcy and im getting the tranny today from the junkyards hopefully the legacy did not come with 2 differnt gear ratio tranny
  17. i dropped the tranny from the bottum first i took the whole exhuast system off in one peice 6 bolts where it hooks up to the motor and one back near the cat and 4 hangers, and it was off. then the shield between that and the drive shaft, then the starter,shifter,axles,motor mounts ,tranny mounts crossmembers,clutch and finally it was out, its going to take me a lot longer to put it all back together then takking it out,
  18. i blew 2nd out of my 95 awd legacy 5mt and the cheapest tanny i found is 400$ damm but i cant go much longer with out a car
  19. how can i find the gear ratio for my 95 legacy awd 5speed i look at the rear diff and the is just a couple number stamped on the very bottom first it says 314 then a bigger stamped number 51 below then it says KN41
  20. its a 95 awd legacy 5 speed 2.2 with 118,000 miles, just before the muffler there is a huge exhaust leak were i cut it off and tried to clamp it back on, i was only getting 20mpg babying the hell out of it. if i went 160 miles it would cost me 20 dollars the fill it back up
  21. almost a year ago i put a clutch in my car, now iam in the process taking a the tranny out without having a tranny to put back in it when i dropped the whole exhaust in one piece the on the first cat the o2 senser was unplugged would this cause a decrease in gas mileage! help
  22. will a tranny out of a impreza hook up to my 95 awd 5speed legacy i cant seem to find a legacy tranny but found impreza tranny at the local junkyards
  23. i have a 95 legacy awd 5speed with 2.2 . ever since i got the car the 2nd somtimes grinded , and i would double clutch it would fine ,i went wheelin with it a couple friends in some snow in when i was going up a hill that was all snow and went to throw it in 2nd when boom! no 2nd gear at all the other gears work fine just no 2nd gear .how long can i drive with no 2nd gear or did i blow 2nd gear i pieces that are floating around in the tranny. iam going to wait till this weekend to put a junkyard tranny in would it ok to drive it for a few days
