subiemech85
Posts posted by subiemech85
  1. I don't know what everybody's problem with the ea71 is, especially when you consider in stock form the ea81 only has 4 more hp
    with a few easy common upgrades, it will serve fine and feel like it has more power and better sound
    1. NO CATS, it's old enough NOT required
    2. swap in electronic ignition
    3. swap in XT6 alt
    4. swap in weber
    the single range, although different, doesn't seem to have the quirks of the d/r, and is adequate on mud roads in 2 and 3 gear
    4 gear is great for cruising
    end of rant
    $100
    bought the ski wagon for $100
  2. find the d-check connectors, IIRC green with a brown wire???
    turn OFF key switch
    connect D/check connectors
    turn ignition ON
    ECS lamp "should" be ON
    fuel pump "should" operate intermettently, turn on and off every 1.5 sec.
    start engine
    ECS lamp on, with ignition on, check for the fault code by observing the O2 monitor lamp of the control unit (codes 11-42)
    if no ECS lamp, ask for more help, as that is on page 2
  3. take a good look at the seal
    measure the ID, OD, and width in MM ex. 32-47-8
    the numbers should also appear on the seal
    the brand usually does not make much difference, and styles may vary
    then look up the seal at SKF http://www.chicago-rawhide.com/catalogs/457010/stocklookup.asp
    then call your seal supplier and provide them with the dimensions and the skf stock #
    the seal from the example is 12733 which happens to be for bosch type ve injection pump input shaft seal, IIRC
  4. check your fuel, did you put E-85 in?, COULD have a bad tank of gas
    will it run better if you keep it above 3-4k?
    the tps should show a nice steady change in ohm's as you go from open to close, be sure to follow the setting procedure with feeler gauges
    make sure timing is set to 10* btdc, you have ngk bpr9ey-11 plugs and a cap and rotor MADE IN JAPAN
    unplug the maf sensor and see what happens
    you should have atleast a "ok" code
  5. you may want to go with an optima yellow top, better suited for that application
    you are better off going with a pb h2so4 aka lead acid maintenance type battery
    interstate batteries are good, and if you want to save $$ you can buy an "econo" or "blemi"
    if your alt. is outboard mount, go with the xt6 90A
    the "GM" alt. swap is somewhat common, and both swaps have been written up, SEARCH!!!!!!!
    or be satisfied with a mono system or something else low powered, no body wants to hear your resonance or farts :rolleyes:
  6. do you and your engine a favor
    check air intake system for restrictions, stick on a subspeed kit with uni filter
    check ignition system for proper performance, change cap and rotor to napa premium made in japan, switch to accel 8140c coil -- but keep the old one, and the #1 thing to do is put in NGK BPR6EY-11
    check the fuel system, change the filter to a pruolator, inspect the fuel lines
    install quality vac/boost guage with small dia line, 1/8" iirc, hook the line to the port on the intake manifold that has a square head plug in it
    if the line is larger or longer than necessary, there will be unacceptable delay
    use a short hose from wastegate port to turbo outlet port
    inspect the cooling system, make sure you use a NAPA SUPERSTAT or genuine subaru thermostat of the correct temp. with jiggle pin
    change oil, filter, and drain plug gasket use a high quality diesel engine rated oil, CH4+ is the "current" rating, do not skimp as the turbo and hlas will suffer if you do, you should be able to run 15w40 or 15w50 year round but adjust as needed according to climate AVOID FRAM oil filters, they are JUNK. PUROLATOR and WIX are good, along with their private label brands, the "ADVANCE AUTO" AA3600 filter is a PUROLATOR in a red package with a textured outside to hold onto, and when you install the filter, put the bejeses to it, otherwise it may vibrate loose and pour out oil
    BUY CLEAN FUEL AND KEEP IT CLEAN E-85 will work fine if you know what you are doing and how to drive with it it helps if you have 2g of regular to 13g of E-85, but adjust to your particular needs E-85 will give you the capability of making more boost with stock turbo and exhaust, even with significant exhaust leaks if you want to watch AFR, buy a lambda system
  7. do you and your engine a favor
    change oil, filter, and drain plug gasket use a high quality diesel engine rated oil, CH4+ is the "current" rating, do not skimp as the turbo and hlas will suffer if you do, you should be able to run 15w40 or 15w50 year round but adjust as needed according to climate AVOID FRAM oil filters, they are JUNK PUROLATOR and WIX are good, along with their private label brands, the "ADVANCE AUTO" AA3600 filter is a PUROLATOR in a red package with a textured outside to hold onto, and when you install the filter, put the bejeses to it, otherwise it may vibrate loose and pour out oil
  8. go quality!!!!!
    small = cobra 19+
    good features = uniden bearcat pcxt693l?
    good antenna, easy on budget, strong magnet, "powerful" = wilson "little wil"
    best place to mount is usually middle of roof, run cable as needed
    when on the wagon, it was on middle of roof, ran cable through front side of rear door on left side, run cable down, under seat, along center conlsole, to the SWR meter, short cable to cb which was leaning up on passenger side trans. bumpout, or on seat
    if all is good, it will sound like talk'n on a LL :banana:
    I bought the cobra and mic from ebay, SWR meter from goodwill, "jumper" cables and antenna from radioshack, and the uniden and little wil from an independent shack, for "common" supplies, truck stops
    tosh, you can buy a "dummy load"
