Everything posted by 2X2KOB
I had the same problem on the 2000 OBW at 148k. A new transmission fixed it right up! It was a factory rebuild installed by an independent shop, and it was not cheap. I would have liked to have gotten a junkyard trans for cheaper and tried that route, but I was in a situation where I could not do the work.
The last timing belt failure I saw wasn't a broken belt, it was that the teeth stripped off the belt where it passes the crank sprocket. Sounds like yours is pretty far gone, but not broken. Try turning the engine over while observing the belt and cams and see if it all spins, or just the crank turns. You can turn the engine with the starter or a wrench in the front at the crank pulley or if it's a manual trans, put it in gear and shove it a little bit. There are other things that should be done when changing a timing belt - do a search for older threads, it's been discussed many times.
I have had that happen ONE time on the 00 OBW. I started it up, then for some reason shut it off after about two seconds Right after that it was hard to start, took excessive cranking, backfired smoke out through the intake and acted pretty ugly. Got it going and let it run about five minutes, after that it was all right. I got no answers as to why, just wanted to pass on a similar experience. Maybe the computer was confused - who knows?
We had very similar damage on the 2000 OBW from a rear-ender on the highway - insurance payout was about $2800, dealer parts were about $700, a day or two to fix it, good to go. No paint work involved, lucky. It's not too difficult to take it apart. If you can save the bumper cover and you haven't got sheetmetal damage, it should be a pretty straightforward disassembly/reassembly exercise. The dealer's catalog has good pictures to identify what you need. There's lots of weird fasteners though.
I did that a couple years ago and it worked fine. I don't know if they have changed the game rules since then or not. The PDFs are good, but the problem is in the indexing. Although you can always do a computer search to find what you are looking for. Be prepared to invest a few hours in file naming and creating the directory structure. I'll see if I can send you a sample...
Well, it's certainly worth a shot to try and fix it from outside. I think I'd run it low on gas, then clean the seam real good down to bare metal, then rough it up with some 60 grit paper, then clean it with a good solvent like brake cleaner or acetone or MEK or something, then put on a layer or two of JB-weld, maybe with some fiberglass cloth. I'd make a big patch, at least an inch past the seam. Seems like this should work, for awhile anyway.
