Everything posted by JPX
92 Leg Rear Differential
JPX replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a more likely scenario. Diffs are tough little assemblies. But wheel bearings on these cars are a royal pain. 3 of 4 wheels replaced on my 96 Legacy around 100K miles.
trans service question
JPX replied to hogweed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've changed by auto trans fluid A LOT. But I admit *sheepish cringe* I have never pulled out that filter.:-\
HELP**Starter issue
JPX replied to skins's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is exactly how I resolved my starter "click-only" problem. But Cougar is right, a bad cable with corroded terminals or wiring will make a good starter act bad. Photos of the worn contacts (89,000 miles) in the solenoid and the new ones before installation.
how far out does the converter sit when completely dropped into trans?
JPX replied to xrturbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA reference photo of the torque converter in place with the engine removed. Mine stayed put when the engine came out.
towing issuses?
JPX replied to offroadbryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeadoo HX is about 400lbs. Single trailer is a little over 225lbs with the cargo tote I stuck on it. Figure another 50lbs when you throw a couple of tanks for gas in the trunk. Double trailer is 500 lbs - haul more gas, stuff and a total of 800 lbs of jetskis and it really works the car hard. Shorelander.com The only thing you will notice with a <1K lb rig is the normal clunking from the ball/hitch. Driving experience is really not much different unless you are on a steep grade. Braking holds up pretty well. Post a pic of the fishing boat!
towing issuses?
JPX replied to offroadbryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1996 2.2L pulls single jetski easily. Just don't count on being the fastest guy on the highway (and would you really be anyway with a 2.2?:-\) This was the typical towing configuration for a better part of 4 years. But pulling a double trailer which is a lot heavier plus another 400lb ski was a lot more work. Glad I didn't do this too often. Unfortunately a failed water pump lead to a blown headgasket at 135K miles. I would have thought I'd kill the automatic transmission first. But the transmission seems to be holding up pretty well. I made sure to change fluid much more frequently.
Alternator Question
JPX replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is interesting to me as well. My Autozone alternator runs really hot as well. And I suspect the bearing is starting to make noises it shouldn't. I'll have to check out the Subaru alternator option. Thanks for the tip.
hitch advice needed please
JPX replied to Zephyr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had bought the SeaDoo before buying the car. I did the hitch thing on my 96 Legacy - Class II. Worked great for a hitch mount bike rack too. One famous trip for us was a Yakima RocketBox and a Pounderhound on the roof with bikes on the back. Here is a very light duty hitch on my friend's WRX. This holds a hitch mount bike rack very nicely. But the rear hatch does not clear the current rack's pole. This is where a swingout rack would be more convenient.
Flex Plate Bolts
JPX replied to lakroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had to use an offset 12/14mm box wrench to get them out on the top side. get a friend to hold the crankshaft so you can put both hands on it to keep it straight. They weren't on all that tight on mine. There was no combination of u-joint extensions I could come up with that would take those things off from underneath.
Secret Subaru compound sprayed on wheel wells for rust protection!
JPX replied to subaruman2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, there are two factory "coatings" I can think of. The first is something that looks like typical undercoating. The second is this blue waxy stuff that I had never seen before until we started to install a trailer hitch on my friend's 2006 WRX. If you want hardened coating, you could Rhino-liner or Line-x on there. But that gets expensive for this application.
Re-using a timing belt?
JPX replied to a97obw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should just put on a new belt. For the amount of hassle it is to take off the belt in the first place, it is not worth having to get back in there again.
96 Legacy (automatic) rough idle
JPX replied to mccullough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCleaning the throttle body can help a little bit. I just sprayed carb cleaner at the throttle body while running to blow it out a little. It did change the way the rough idle in gear felt - although it never really made it go away.:-\ Now that my entire engine is out of the car, I can really go to town on cleaning the entire intake manifold.
oil leak
JPX replied to hayden 96 gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs suggested above, if it looked anything like this underneath, then it is probably coming from here: And you'll need a new one of these:
2.5l lifitng points
JPX replied to paulivan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used the rear loop by the O2 sensor and main engine harnesses for the rear lift on my 2.2L just yesterday. Then the front loop where the previously mentioned AC bracket goes - take only the compressor off, not the entire bracket.
Replacing water pump on 95 legacy wagon
JPX replied to elmwood22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo need to pull oil pan for a water pump change. And I agree that OEM seals are the best choice. I hate the idea of paying a lot more for these parts. But I hate the idea of going back in to replace stuff again even more. My factory water pump died around 90,000 miles. Whatever pump the repair shop put in gave out at 135,000 miles - and it has cost me my headgasket.
Skidding with AWD?
JPX replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat tires are you running? This has a major influence on how the AWD will react. I have all-season tires that tracked well in ice/snow. But you could break it loose if the tread got gummed up with packed snow. I imagine snow tires could produce more controllable results. Rain is a different matter - the tires pushed water out of the way quite well and the AWD tracked super predictably.
