tidd1340
Everything posted by tidd1340
  1. Thats mint for an older NY subaru!
  2. All went well..about a 40 mile drive to and back from home depot.
  3. Sorry,forgot that! 1989 GL sedan EA82 5speed D/R..thanks!
  4. What would be a ballpark cost on doing these with decent parts?
  5. Im going to check the motor mounts,as it seems Im having a problem keeping the exhaust manifold gaskets from blowing out.Ive read it helps to soak the gaskets in water first(the paper kind)is this true?
  6. Is there 1 or 2 tranny mounts on these?
  7. in my 89 GL D/R 5 speed,especialy during shifts. Worse when you lug it....both shifter and d/r lever..thinking its a tranny mount..any good ideas floating around on these as were to get or ez fix?
  8. Decided to wire up the 89 GL for trailer lights. I guess Im in need of a 3 to 2 wire converter..is that correct? Any good places to get them?
  9. I dont plan on anything heavy. Just wanted something to use with my utility trailer.I doubt i will bother putting a light plug on it for highway use. Time will tell!
  10. Pretty simple really. Just used U-bolts through the bumper,and its bolted to the trunk pan in 2 places.
  11. I tried posting bigger pics..cant get them to work. Is there a way to link to photobucket?
  12. Had the day off with the big storm in Buffalo,so i made this today. Had the materials laying around.It should work fine for the small 4 x 8 utility trailer I tow 2 times a year.
  13. http://www.ultimatesubaru.org/forum/showthread.php?t=3462&highlight=studs
  14. Well i did a search and it looks like I found my answer..looks to be an isolator..and Im about to remove it.
  15. Can someone tell me whats leaking here? And can i remove it?1989 gl 1.8 F.I. nonturbo..its right out of the fuel pump.
  16. for my 89 gl. Just bought a very small coleman pop-up(its just a tent on wheels,around 750#),and i need to be able to tow it about 3 times a year short distances. Did a search on the board and came up with a few ideas,but the info was dated. Wanted to see if there are any more ideas out there,or if someone is trying to get rid of a hitch..thanks!
  17. Did you buy from this guy? http://cgi.ebay.com/ebaymotors/85-90-SUBARU-LOYALE-GL-GF-DL-FE-RX-RADIATOR-86-87-88-89_W0QQcmdZViewItemQQcategoryZ33602QQihZ013QQitemZ230021643901QQrdZ1
  18. Anyone have a place online that they had a good experience with?
  19. Thinking off pulling out of my engine on my 89 gl. It only has 72,500 on it,and I want to do a complete gasket job on it as it has a few leaks,and I want this thing to last. Is this a tough job? Do you take out the motor and tranny(5 speed) a 1 or seperate? Ive done a few v-8's,but never a Subaru..any good tips?
  20. on my 89 GL. Its stuck on heat,but I want to be able to switch to defrost,bilevel,etc....fan works fine. Is this a vacum operated deal? Where is the best place to start troubleshooting? thanks!
  21. It hasnt been started or will not be started again untill its fixed..thanks.
  22. Had to cut mine ..is it going to still read correctly if i solder it and use shrink wrap?(1989 E82T F.I.)
  23. Looking for the stock system..need the pipe from the y pipe back and the muffler..not much luck with the locals. Anyone have a good place to look?
  24. Anyone have a link to one for an 89 GL 4 dr nonturbo. I need everything behind the converter. Any good sources out there?
