Subaru_for_LIfe
Everything posted by Subaru_for_LIfe
I myself is very happy with Raybestos ceramics, then again, I'm an old guy and drive like an old guy on the road But a lot of the members who also are active drivers seem to prefer name brands such as, Mintex, Axxis, ECB, Hawk etc. Most of them have specific models for different usages, such as tracking, rally and street use etc. Head on over to Legacy Central message board. There you can find all kinds of mods and upgrades for our generation of Legacies (warning: your wallet will not appreciate you visiting that site)
Totally different caliper designs. Your N/A front caliper has a single piston caliper. Tha Turbo front caliper has a dual piston caliper. The Turbo's rotors are a tad larger than N/A's. The OEM part numbers are all different for that matter. Therefore, the Turbo pads must be a tad larger than the N/A pads.
I'm on my second EJ22 motor rebuilt and both of them have those marks. So I guess It's normal. And I've checked the thrust bearing and it was within limits. The bearings are pretty easy to get except for the rod end bushings. And also, if I may say so, be very careful and frugal with the sealant when you put the two blocks back together. Keep us posted with the pics
Howdy Phillip, All those special tools are definitely nice to have but not required. You could get by with most common garage tools and some improvisations. If you do a search, you'd find various methods used by other members including but not limited to breaker bars while cranking the motor to novel factory special tools. You need to stay away from AllData and hang around here more often. I have never taken off cam pulleys for T belt and water pump job. And yes I've always used the 'C' clamp to compress the actuator, just do it slowly like you've said. Find a small pin to fit inside that little locking hole on your tensioner in advance. Why didn't you get a Haynes manual?
I'm assuming that you'd bought it brand new. When I bought my Forester back in '03, I went through the same thing. Mine was even worse, it smelled like rotten egg, although not that strong. As it turned out it was the catalytic converters going through the break in period. It lasted for about 3-4 months before going away. By any chance yours is 100% parts and assembly in Japan? And it's okay for the A/C to drip that much water. And it's also okay for it to keep leaking way after you'v shut off the A/C and/or motor. Congratulations on your purchase and welcome to the board. You're gonna love the Baja
If the tranny was working fine until just before the wifey hits the water puddle.... Since it's an AWD, whenever you drive through water puddles, the differential has to work overtime. That might be a culprit. I'd also check the tranny computer as well. But since it was fine just before she hit the water puddle, I seriously doubt that it's mechanical. Keep us posted.
You already have your answer right there The crankshaft thrust clearance is 0.25mm (0.0098in) compare that to your 0.125inch that alone is over ten times the allowable limits. That's just what you can see, who knows how badly worn/corroded inside. Any motor that's lying around in a shed for over 5 years without proper treatment must be considered shot unless proven otherwise. I'd take that motor back out ASAP if I were you.
I'm not a mechanic but sounds like ECU (computer) is confused about the actual temperature of the motor. Did you check and/or replace the temperature sensor. You might want to check the O2 sensors as well. Do not take the fuses out for the fans. You'd rather have the fans running than no fans at all. I'm sure other knowledgeable members will help you out. Good luck.
Very nice looking and well maintained car, congratulations Legacy777. A couple of questions, what are those red circular things behind the throttle body? Also, which muffler do you have on and how do they sound? I need to replace mine and eventhough I'd like some performance boost, I don't think I'd want the obnoxiously noisy ones. Good job man
It seems only one person has removed the air vents on the passenger side. Well, I had time this morning and played around with it with a small flat screw driver and got it off without breaking anything. There are two metal clips attached to the bottom of the air vent on the ends. Once the vent has been pushed into the dash opening, the metal clips on the vent catches the bottom lip of the dash and holds it in position. To remove, one simply slides a small flat screw driver between the bottom of the vent and the dash lip and lifts it up, then pull outwards while keeping pressure at the bottom of the vent. It took may be 10 seconds per vent. The reason why we love our Subies so much, simplicity. I have the pics but need to look for a hosting service first
