Everything posted by SevenSisters
Do U.S. Brake Parts Fit a European 2000 Forester?
SevenSisters replied to patricko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow Iceland, what a great place for a Subaru. Try the internet looking for a Bendix, etc. part number for each of the two vehicles. See if they match. My guess would be that they are the same. Good luck.
Rad cap damaged in transit?
SevenSisters replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHitch hiking on cookie's suggestion, Put the radiator cap on the radiator. Make up a little manifold with a gauge and hose that will screw into the radiator bleed hole. Any other port or removed sensor hole in the cooling system will also work Pressurize the cooling system with a bicycle pump 'till the cap pops and note the pressure in the gauge.
Front seatbelt doesn't retract far enough
SevenSisters replied to jonzilla's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt wouldn't surprise me if they fixed this potential safety defect for free. Check with the dealer.
Struts....abs light question
SevenSisters replied to Subaru X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn first generation legacies. there is an ABS diagnostic LED under the passenger seat. Don't know if it's applicable to later models. Might help isolate the source.
SevenSisters replied to Subaru X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe gap between the tone wheel and sensor may have changed, triggering a fault light.
Potential AT/Differential problems '91
Josh, Thanks for the suggestion. I tried power braking with no whine, just some roughness. If anyone can add to a solution, please jump in.
torque converter mess!
Guys, I'm encountering a transmission or differential whine on a '91 auto Legacy. My limited experience would suggest a bearing. Would anyone that's had thier diff/trans out venture an estimate on how big a job it is to get the differential out once the axle stubs are removed? Any special tools, etc? Thanks
I’m getting a loud whine from the front of the ’91 Auto Legacy. It is present always and changes pitch on acceleration and deceleration. It is present if I shift into neutral at speed and coast. Revving the engine in neutral does not change the sound. It does not change if I make turns. It seems very load dependent. When the load changes, like at the top of a hill, it will “squawk” if that’s the right term. I changed the front differential oil with no change in sound. There was a little pile of fuzz on the magnet. ATF fluid looks OK. No torn boots. Going under it tomorrow to see if there is anything else obvious. What do you guys (and gals) think? How much trouble am I in?
Legacy 00 rear brake job q's
SevenSisters replied to seb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe you can back off the adjuster screw through a slot in the backing plate. Since you've cooked the bearing grease, expect a "snow tire" noise to develope in the rear. Then it's time for a new bearing.
IAC cleaning revisited
SevenSisters replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks! I'll try to get it back like it was.
SevenSisters replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet me hitch-hike on this thread. My IAC has slots in the electrical cover where the phillips screws go in for some kind of adjustment. What's this all about?
Tranny or Axel Problem
SevenSisters replied to dc8fr8dog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board. Do you have Pirelli tires? (just a joke). I would rotate from front to back to see if that makes a difference (out of round, bent rim, not torqued right).
Just fixed but here's my accident pictures
SevenSisters replied to slo5oh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like rubber. Did you tangle with a semi?
battery draining - noobi and new car
SevenSisters replied to paul-n's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX14.5 volts output sounds good to me unless I'm missing something. Start pulling fuses to try to locate the drain. To be sure, have the alternator and battery checked. I had fits over a battery I thought was good. How old is it? Original? Get a new one. A bad battery can screw up a good alternator.
Cleaning the Engine compartment, where to start?
SevenSisters replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy only caveat would be to rinse after the engine has cooled down to reduce thermal shock of the sensors. WD-40 probably will break down some rubber components, but not nitrile or other under hood materials. Just don't soak 'em in the stuff. The kerosene based engine cleaners have not hurt my old 'ru and it smells great for a few days.
HEPA Filters
SevenSisters replied to wjack33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCabin air filter? Didn't have'em in '91. It may sound good after I clean a half inch of dust and dirt off my dash, but this sounds like another dealer service opportunity. How much is a Purolator air filter that will go 30-40K and suck in millions of cubic feet (cubic litres whatever) of air during it's lifetime? Buy a screw driver and a furnace filter. Ya a furnace filer, that's the ticket. I'll have to remember that one, Thanks, #19!
Why dealers charge more? Found some answers (long)
All good points. Next time you see him (her), ask what their gross profit is on parts and service. I think a lot of members would be interested. Thanks.
2000 Forester Exhaust Options
The reason I asked where you were from is because some northern, salt infested areas may benefit from stainless. Let us know what you find and how much it was. I still don't think 5 years is bad for a conventional system. I wish my '91 had stainless fenders.
Stainless sounds expensive. If you went 80K on the original check out Autozone or some other aftermarket supplier for a welded unit and save some bucks. What city on earth are you from?
Main Fan not kick on
SevenSisters replied to Zeky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind the thermoswitch (one for ecu), unplug it, jump the two pins on the connector, and see if the fan starts.
CEL, engine idle control code
SevenSisters replied to dragon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd guess that K&N filters are about as effective in boosting performance as fuzzy dice. Can you reinstall the OE components, clear the computer, and see if that helps?
$15k-$20k to spend - which used Subaru?
SevenSisters replied to skthom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX20K? Buy a new Legacy sedan.
Outback replacment rotors
SevenSisters replied to kjadams2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome cars need to have the hub pulled to remove "captive" rotors. Sure ain't that way on a '91. Doubt if it's like that on yours. A nice setup Subaru has. Find a better mechanic (more honest). Just have to remove the caliper. About 10 mins. work max. As far as rotors, I never had a problem with Autozone/ Advance Chinese rotors, but they do seem to wear fast. All the better for rustbelt conditions to prevent pitting.
New kid on the block
SevenSisters replied to oystein's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, Two (2) up!
SevenSisters replied to oystein's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOil is oil. Just make sure it meets or exceeds the classification rating for your car and is the recommended weight. Boy I'm gonna hear about this.
