Everything posted by starsea
My 03 OBW has 108000 miles on it so I guess its time to change the timing belt. What parts do I need to order? I know the belt, water pump and tensioner. What about the oil seals on the camshafts and thermostat. I assume the cover have three gaskets and a seal correct? Does the seal need replacing too? Any other parts? Also is this a job that any decent mechanic can do?
Lift points
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks. What about using a shop lift? The big hydraulic ones. -
waterpump and Timing cover ???
starsea replied to Prospeeder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your car still doing okay after leaving the covers off? -
Doesn't the 00-04 OBW have 7.3 inch clearance?
Yes a lot to learn, like having to put a fuse in a hole to switch to rear wheel drive only when using a doughnut. Glad an owners manual came with it. I've seen a lot of interesting stuff here so far. Lifting looks easier then the Suzuki. With it I just use a taller fatter tire. http://www.1010tires.com/TireSizeCalculator.asp showed me just how big I could go. And how much it would raise it.
The plastic is already scratched up and looks like it has been scraped a few times so that isn't a real big thing to loose sleep over.
Hi, I've been driving Suzuki Sidekick 4X4s since 93 (93 & 97). Both were totaled. Wanted something with better gas milage and bought a 2003 Outback Wagon. I assume I can take it off the road for some more then mild but not quite wild adventure. Just how far can I go with a stock setup? Water depth, curb hopping, deep sand and shallow mud.
Wind Noise
starsea replied to excal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I just turn the music up. <heehee>
