Everything posted by malamute
Hi Jerry, I may be wrong about this, and I will check my boxes tonight, but I think you sold me a Justy engine a couple years ago off of Ebay. How about $30 Just let me know how much shipping is going to be. Matthew
I have a 91 EFI Justy with a blown coil. Since a replacement costs as much as the car, is there any other Subarus with a compatible coil. My junkyard doesn't seem to be stocked with Justys anymore. Matthew
If the transmission is still good, then it isn't a bad deal. If the trans is going bad, you may want to get going on a search for a 5 speed trans and related gear. For me if it was rust free 3 door, I would take it. But I have more than enough spares to make up for a bad CVT transmission. Matthew
13" Justy wheels ?
malamute replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll go out and measure one of my steelies for center hole dimensions and back spacing. For winter duty I run Nokian NSW's in front and old Hakkapelettia NC 10's in the rear. I simply don't get stuck with these tires. Matthew -
I actually bought it off Ebay. I actually paid the 75 bucks for the engine and trans sections of the Justy manual from Subaru (there are 6 sections all together). I had to buy the manual because my Chilton's had so much incomplete information. Then I found the incomplete set on ebay and got it. I think I paid 10 bucks for the other 2 books. Chilton's are decent enough for beginners, but if you really want the nuts and bolts, get the factory manual. I even have one for my LR Discovery II. Matthew
It should read "Do Not Open" instead of "Do Not Cut" Matthew
@@@ !!!Subaru Justy!!! need recruits @@@
malamute replied to Dukie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nothing like those systems. In a Justy the rear wheels are driven from the front diff. There is no center diff per se. You will find this out when you try to make a turn with the 4wd on pavement. It gives a true 50/50 F/R split. It also means that you must be pointing in a straight line when you hit that button.
Show me your Justy Projects!
malamute replied to djkindt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Willing to trade for a good 90 to 94 3-door body? I need a road trip to N.C.! I have to get my new house done before I can work on any project car. Hopefully in the summer I can start the build of the motor. I am still toying with the idea of either a 323 GTX transmission or a Toyota All-trac unit. And in case you were wondering you can ship a Justy block UPS. It weighs 69 pounds. Matthew Bos -
justy balance shaft timing
malamute replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pages out of the manual... And yes, one day I'll learn how to use my scanner correctly without breaking the binding on the manual. Sorry for the delay, I hope this helps. -
Just got a Justy, radiator alternatives?
malamute replied to alkalineJUSTYtrio's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just bought one of Ebay for $109. Not a bad deal. It even came with oil cooling lines which I am trying hard to figure out how to use. -
Thanks for the pro-Justy *************** slap I'll look it up when I get home. -
Yup, that a Junkers engine on top. But I am trying to find more info on the bottom engine. The opposed boxer is cool for diesels because two cylinders fire at the same time, distributing the ignition forces evenly through the case. The current Subaru boxer would probably go through engine mounts like nobody's busines in diesel mode. I just find it facinating.
Both were made for airplanes. The top one was for a high-altitude bomber. I have a friend with an 85-foot ocean tug. That has a serious opposed diesel in it. Very cool beans.
Any body have any opinions on Subaru making a diesel? I really don't care if they sell them in Europe, but I would like to buy one in the US. The problem with using a standard boxer block is that I don't think it would be strong enough to handle the combustion forces. I'm not saying it can't be done, but I have a couple of pictures of horizontally opposed diesel engines to give some "other" ideas.
Sorry to say, they don't exist in the known universe. You will have to have them made. Or, just have some more metal welded on to you existing units. Matthew
Con Rod Bearing - 39-45 N*m or 29-33 ft*lbs Main Bearing Caps - 41-47 N*m or 30-35 ft*lbs Oil clearance Con Rods - .020-.053mm or .0008-.0021in Oil clearance Mains - .014-.043mm or .0006-.0017in Other useless information upon request.
I can get those to you probably Friday night when I return home from a business trip. I won't ask my wife, she won't be able to find in the manual. Matthew
'88 RX and 7wk Siberian Husky Pics!
malamute replied to SuBrat84's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A 1990 would have unequal length CV's where as a 1991 and later GL EFI will come with equal length CV's. Torque steer was a problem with 73 ponies to unleash!
