aartod
Everything posted by aartod
My 90' legacy has been making quite a bit if noise from the rear end of the car lately... It has been making a low pitched growling noise (rar-rar-rar-rar) that increases with speed. I figured it must be a wheel bearing so I jacked it up tried to feel for any slop or play in the bearings but everything seems tight and smooth... So I checked the rear diff and the gear oil was clean and didnt smell burnt and I topped it off. The center support bearing seemed fine as far as a visual inspection goes. Could it be the rear cv joints? I have never had experience with rear ones - only fronts and its obvious when they go bad! Let me know if you have and suggestions or things for me to check and your subaru guru insights!
I have a 1990 legacy and I just pulled the engine to change the clutch and the bell housing side of the transmission is leaking quite a bit of gear oil. It does not seem to be from the imput shaft seal either. Could it be from the mating seam running down the center of the trans? Where else could it be leaking- there isn't much else in the belhousing... I do not have the money right now to replace a trans... Is there a stop leak type of additive that could help? I need my car back on the road by Monday and didn't antisipate this problem!!!!
Quite honestly, the car is on its last legs... But then again it has been for 2 years. Right now I'm trying to do the bare minimum... The clutch has been slipping for over a year now and I have just been driving it very easy. The engine burns oil- not visible blue smoke- but it consumes about a quart a week, and barely leaks any. I have a rear main seal leak I plan to address as well when I do the clutch. I love the car, but it's time for a new suby sometime very soon. So, to answer your question, I'm just looking for the quickest- least painful procedure.
Hello, I have a 1990 legacy and I am going to change the clutch this weekend or next... I have been reviewing manual and can't decide whether to pull the engine or drop the tranny. They both seem like a really crappy way to spend a weekend! What experience have you all had with this? Which was easiest, or quicker, or least painful?
Soooooo.... I have a leaky steering rack- really leaking! The problem is that I currently work two jobs and have no time to deal with this- could I possibly disconnect the power steering lines and plumb them together and just have manual steering? Would the rack rapidly fail because of this? I am going to replace it soonish, so I don't care about re- buildablity of the rack assembly. Let me know your feedback on this... On and by the way, my old subie is on her death bed, so I really don't want to sink much more money into her!
