2
Everything posted by SubaruJawn
Pulled the heads and well... Crack between the valves, on 3 sylinders
i'd love to install an ej22 but costs so much to make it all work i dont have that kind of money yet, i plan on ej swapping but it will take a long time.. i already have a stainless uel header that i have atleast...lol
no we dont have emissions tests here, i do have a glasspack on at the end of the stock exhaust system. as formaking own Y pipe i dont have the skill nor do i have pipe bending tool. i might knock out the small converter to make it louder.. EDIT: and its out, saoking in kerosene to clean up all that grease, grime and well you know wha else...lol Kerosene soaked well gonna install XT6 clutch, and maybe shave the heads for more power... what are your guy's thought on shaving the heads?
i wish i had everything to throw in an ej22 ! i so would love it.. i know the xt6 is stiffer, as i drive one way stiffer than loyale.. i hope the xt6 flywheel (being lighter) would help me climb hills... 90hp sucks climbing hills yeah i knew about changing gaskets i got this kit. http://www.ebay.com/itm/220699367298?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
in the process of replacing the head gaskets on my loyale.. is there anything i can do (while its out) to increase HP ? also i plan on chagning the clutch to an XT6 clutch, from what i understand i need the xt6 flywheel and then the xt6 clutch will fit ?
changed the oil, engine runs smoother and better, not saying this fixed the hesitation... after resetting the ecu i got 2 codes 11- Crank Angel Sensor (no idea where this is loacted) 34 - EGR solenoid or circuit
ran seafoam in the intake, tank & a bit in the crank case.. installed new Disty Rotor. Still Hesitates. next will be oil change and fuel filter.
No i havent yet. but will when payday comes (tomorrow) an oil change is in order, it needed an oil change when i boufgt it and 6 months later i still havent changed it.. i have ran seafoam once, may be time again. and run some through the crank case before oil change. would needing headgaskets be some cause ? i know he needs head gaskets
i currently have hesitation issues with my loyale. i checked for trouble codes, i got 23 and 32 so i cleaned the MAF sensor helped a bit i think after resetting the ecu i get no more trouble codes just blinks 5 times pause (and hhrepeat) i still have the hesitation, some times so bad the whole car rocks back and forth (like riding a mechnical bull) clears and can continue driving at times it very little for a few seconds. 1 fine beautiful day (75degree temp and sun shine) went to work (a 20min drive) absolutley no hestitation.. for the record i have all new plugs and wires which are all NGK's. new disty cap. what can cause this hesiatation ?! cant figure it out, gotten me all Pi**ed off many times. any help is greatly appreciated
Love the work you done ! i need a set of rear disks for my loyale.
Thanks and i'm running 195/75 R14 on the rear and the front is 195/70R14. i have to run in 2wd till i can get all 4 matching
new pics
Now Road Legal again. upgraded the LED Bulbs to bigger and brighter LEDs.
yes bratman is correct.\
no it doesnt Rub, i just thought if there was a way i'd do it just to make it look better.
is there away to bring the back wheel out more ? with out the frame drop ?
rear diff clearance 8 1/4" 11 1/4"
i'm running 14"s from Mazda B2200 total diamtere of the rear is 25.52 " for every 2" bigger the tire half that will be closer to the body.. i measured 14" from center to body given that 18" will fit i backed off 2" 27" is 2" bigger than 27" so the 27" will be 1" closer to the body. if you go 4" lift you will have a hell of a time getting it installed, the 2" i didnt need the frame drop.
Yup, looks good with just a little lift. i drive them... i noticed that the brake rotor has 4 bolts and after some search its 4x90mm is there such a car rim with 90mm 4 bolt spacing ? has anyone tired to install studs there ?
i drive my subies, they are cars.. i drive them...
because i dont do that to my subie's...
2" Lift insatalltion Complete a little difficult but installation was a success ! Thanks ADF !
did some work today. welded the studs in the hubs, and installed the rear 2" lift rear installed in this picture the front should be in tomorrow.. i jacked up the front 2" to see how it would sit when done. here is a teaser video: (rear lift not installed in this video)
Great to hear !, my front axles are New i shouldn't have to worry about them breaking...
