Everything posted by Eljefe
Towing a 98 impreza MT on a dolly 150 miles
Eljefe replied to 75subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the drive shaft is disconnected from the rear diff. it will be fine.
Eljefe replied to 75subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow/Why would it do that if the drive shaft is out if the car??
92 Legacy Touring Wagon: Automatic NO 3RD OR 4TH
Eljefe replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have almost the same problem with my 90 Wagon, only it's 2nd and 4th gear. I'm real leery of getting a tranny from a junkyard just for the reason you mentioned.
Japan 4EAT
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's at Enginereplacement.com They get them from Japan, A friend of mine got a Trans from them and was happy with it.
Japan 4EAT
Anyone know if a Japan 4EAT will mount up to a USA spec. Legacy? Mine has a dead 4eat awd. I found a 4EAT AWD from Japan and just wondered if it will interchange.
Auto trans compatability
Eljefe replied to Mike W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was wondering the same thing. My 90 WGN AWD Auto is losing 2nd. gear, I ordered a used tranny from a place in Wisconsin but they are giving me a major run around! I found a really nice 95 here in Tucson but it was hit in the right rear wheel pretty hard so i'm not sure about the rear end. Dito on Josh's web site !! It rules. P.S. BEWARE OF MID-CITY AUTO SALVAGE in Milwaukie, Wisconsin!!!!!
Which Cars came with the "good" EJ22 motor
Eljefe replied to mtsfabman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne port for each cylinder instead of 2 cyl's into one port.( Exhaust ports)
spark plugs
Eljefe replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've always used an old spark plug boot on the end of a large diameter philips screw driver, it worked very well.
HELP!! 90 Legacy Auto
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcoloradosubarules... check your PM's.
Dead Miss!!! (sometimes)
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt finally had the missing problem while I was at home!!! I got out the engine manual & the multi meter and found out it was a bad fuel injector. #1 cyl.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure, i'll scan it and send it to you. It is easier to do if you take the starter out, the band adjuster is on the top left of the trans. right behind the starter.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I got my tranny manual from the dealer. I read through all the trouble shooting areas and found that all i needed was a band adjustment. I put a half turn in on the adjuster screw, Good as new!!! shifts just like it used to..
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've checked for ECU codes all are OK.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLOL I just went to Auto Zone and there it was!! It seems to work really well, The Subi is idling much better.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf i'd just open my eyes i'd find it !! LOL Well, i'll see if that helps.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere do you get Sea Foam, i've not seen it??
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, i've ruled out plugs and wires because I replced both and it still does it. When it is missing it's running on 3 cyl's. then it will clear up. I have run Redline Injector cleaner thru it, after that is when this started.
90 Legacy, Auto, non-turbo. After I drive awhile and get the car good and warm, then park it for 45 mins or so it will drop a cyl. on restart sometimes. Not all the time it's very intermitant. I have replaced the plugs and wires ran injector cleaner checked for codes, Nothing . It only does it when hot, no engine noise, starts right away so it's doesn't seem to be a fuel pressure problem. I did manage to get it to do it once while I was home so I started pulling plug wires off and found that #1 didn't make any difference. The only thing I can think of is an Injector starting to flake out, any other ideas??? Thanks..........Jeff
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I went to the Dealer yesterday to order the trans. manual. I talked to one of the service techs. He said the problem is probably the seal on the piston that actuates (sp) second gear. It involves a complete teardown to get to it !!!! So, I'm trying the Lucas trans fix until I can come up with enough $$$ to fix this thing. He even suggested trying it to see if it makes any difference.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not big on those either, but I have used Lucas products in the past. The fuel system clener and oil additive. I use Restore all the time, I put it in another vehicle of mine with mechanical gauges and noticed a small increase in oil pressure, but a bigger decrease in temp. Living in Hell (arizona) you need all the help you can get.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe slipping in reverse is mostly when it's cold, and the slipping in 2nd. gear in under moderate throttle. Al the other gears are solid shifts. Guess I should go order the trans. manual from Subaru.
Eljefe replied to Eljefe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHello. I checked it, but haven't changed it. It is clean and red with no smell of burned fluid.
Trans is starting to slip going into reverse & 2nd gear!! It just started a couple of days ago. Anyone know what causes this and how to fix it before it gets any worse.?? Thanks....Jeff
Rough running 1990 Legacy
Eljefe replied to Brutewrench's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmmmm... Overheated ? I'd look at a head gasket. You could do a leak down test.
Horrible EJ22T Clacking
Eljefe replied to TheSubaruJunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 90 Legacy does clack sometimes when I first start it, I just shut it off and restart and it quits doing it.
