Everything posted by True2Blue
WCSS10 Location and Date Set!
True2Blue replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
dangit!!! i go to iraq on august 18th -
blown 3 axles in less then a week
True2Blue replied to True2Blue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
im gettin a diff hanger and m bar spacers for a great deal. im using whatever axels i can. -
click my photo link theres only a few but ill be adding more
at the moment with saving money to buy an rx and fixing up the wagon i cant afford a $85 diff hanger. im already buying tires from scott. and axels arnt cheap. i have orders with a few people. tryin to save money:rolleyes: . justin is really helping me out:) (thanks man) Front window, front winch bumper,super swampers for my split spoke pugs, diff drop kit, steering wheel, bedliner for the ru's body and interior plastics.. ive got alot to do. -
Justin is making me a 3 inch diff drop kit. That will fix it all. Thanks guys. -
well my real question is will my axels stop blowin out? -
okay today i went to evans creek and played with the ak47. well when i got to enumclaw i was turning in the safeway parking lot and the axel popped:mad: yep the AA lift sucks cause the rear diff isnt low enough the axels pop right out. the rear passenger side every time. anyone have a hanger for a 4in lift? or should i just space the m bar more? (cause the diff angle will be off due to the pivot point)
still can't find a cool steering wheel
I guess ill do that. I have a certain one I want. -
Im in black diamond for a few days if you wanna meet up. Ill check out the steering wheel and ur ru is lookin pretty sweet. Id like to look at it -
$100 aye. It looks good. What do you mean needs to be modded? -
the very begining...
stumped... new ea82 overheats
Swapped a rad outta a 91 and blead the system now it runs right. Now... im poppin rear axels... I just pop'd one driftin a dirt road corner. 4 inch lift.. I think the diff isn't dropped enough. I think it needs another inch on the drop. -
Ill do that in a few minutes im gonna put my original radiator back in. -
Well once again I am going with the ej22. I heard that there was an axel with u joints instead of the ballbearing setup. Im gonna look more into it.
I swaped the rad and its has new hoses ... -
New as in freshly rebuilt. No more then 600 miles on it. I've been rallyin it so its had lots of bumpin up and down and hill climbs. I've been toppin it of ill do the hill trick tho. It will over heat just driving down the road -
Timing is on radiator swapped full of coolant. Both fans work. Even pulled the thermostat. Im stumped please help its a new engine
I found a ej22. I can't find the swap info. Can someone post a link? Like I said im on my sidekick not a computer. I wanna make sure I gather everything ill need before the swap.
FI eatin gas like crazy
Well it runs hot. I know a can can do that. But to be honest I like the sound of straight pipe. Advancing the disty actually improves performance depending on the position, mine is all the way clockwise so advancing it a tooth will give me play room in the best performance zone. I know I sign'd for the job id just like a little peace now that im back home. Well the engine is new the compression is good... -
Im not stupid I know a clogged cat cuts performance. Yea the plug looks like it was hit. Either that or welded from the heat. im kinda lookin for friends on here not people who lash out. Its just text and internet. I think rod 3 is startin to knock. So the ej22 is comin soon. Id really like help. I just did 7 months of gettin yelled at by drill sargents. Gimme a break -
Im gonna advance the disty a tooth and cut the cat off. It over heated and knocked a plug shut. Dangit! I replaced the plug. Well im puttin the ru up on the lift tonight and replacing the rear diff. Also gonna make the Y for when I cut the cat off. Ill be lookin for a ej22 or 25 soon... -
C E L? Idk um its all clean I cleaned the fuel system. Im about to cut the cat off. Im runnin straight pipe. I hate cats they rob horsepower. The only thing it does is kinda bog at high speed 4 and 5th. So it couldn't be a fuel pressure regulator. -
I know it has 26's on it but still its eatin gas like crazy. The air filter is good. It smells like its runnin rich... any tips? Never really had this problem with a FI
