triiifashions
Everything posted by triiifashions
I have a 98 subaru legacy sus limited and have a few issues my main one right now is it strugglin starting. Seems to take longer than it should and sometimes sputters before starting.also sometimes when starting there is a loud thump under gear shift between the seats from under the car??? Thump happens right as car is starting and it sputters a bit then a thump or two and then fine!!!
yea i think i will just take the old 77 ford through the creek and leave the subee in the dry
well ..... i drained out a couple cups and has been ok since i think the stick is more sensitive than i thought also you must insert the stick with the picture of the oil can right side up this thread tells me that im not as stupid as i thought subees are just picky and sensitive ....may be i should but it some flowers:slobber:
so..... i changed my oil the other day... i have changed a few hundred oils in my time so im not really a rookie.... however.... i filled it up to F then started it and ran for a min then turned off checked level 10 - 15 times added a little to get to F......all good drove about 5 miles came home checked again and was waaaay over F needed to drain some....ok drained almost a quart before got back down to F started checked all good drove a few more times thinking i was all set then did a normal check OVER A QUART LOW!!!?!?!?!? ADDED oil to F (jeeze am i retarded), wife drove to work 60 mi when she got home checked oil waaaay over again looks like almost a quart again??!?!? so needless to say im a bit confused this car is making me feel like an idiot im really concerned about doing damage from not having the right level what am i doing wrong??? figured i would just stop and i would see if any body could help me with some suggestions PLEASE IM FREAKING OUT MY WIFE HAS TO LEAVE AT 7 AM AND I DONT KNOW WHAT TO DO i will check in the morning to see thanks A BUNCH in advance jeremie
WOW this thread got some response huh?!? i thank all of you for your input well its been raining here a lot and the creeks are up so no creek crossing right now we will see how it goes when the water comes down and after all the worst that can happen is a reason to crawl under that sexy subee with my wrench in my hand lol jeremie
WOW killer pics im only lookin at 12-15 inches water max but im still concerned about getting water in the intake and submerging the headers
dash removal is a *************** at best but it is definitly doable the manual is a must and just watch out for your cig lighter wire and your climate control connections and i agree with take your time prob an alldayer even with manual till youve done it a couple times good luck ps i am buying a cassette to mp3 adapter so i dont have to pull dash i hope it works??!?gonna stick with the stock cassette player
well... put in the marvels mystery oil in and after 4 or 5 miles it sounded quieter but not gone. wife took the car to work today 60 mi round trip should know more when she returns sounds close to normal though i think all subees have a "clicky" sounding engine as apposed to say a ford which is a "putt putt" sort of sound?? well... will update later
i have a 98 outback and was wondering about taking it across creeks have been told it is a bad idea but there must be a solution
i was just wondering (i have been told)that it is not a good idea to take your subee in to the water?? and from looking it seems like a lot would come into contact with the water if u did i took my 95 legacy just barely into the creek and the check engine light stayed on after that i dont wanna do the same thing to my "new"98 outback!!! however i live in the woods i dont see pavement very often and across the creek happens a lot if u wanna get to the "good" spot. i know subees are used for off road but may be not the outback????? anyone have any input???? thx in advance jeremie
