rally_wrx
  1. What about axle stubs like these? Did the 'normal stub' you looked at resemble a male axle end? I'm trying to do the same thing as the OP (put male axle ends into the above pictured LSD) but it looks like I should be able to because the axle stubs I have are identical from left to right?
  2. Where are these two axles from? (92 SVX?) I need one of each.
  3. Thanks. The LSD seems like a Suretrac (cam/pawl) unit as opposed to viscous. It was sold to me from a 96 Jap-spec Legacy as a vLSD but upon closer inspection, the two sides of the 'clutch pack' are very difficult to turn by hand. If it was viscous should it turn easily until the fluid heats up? Also, which US cars came with the axle pictured on the left? I've heard 91-94 Turbo Legacy. Is that correct? Also, car-part.com makes a distinction of pre 10/91 and post 11/91. Which one do I want?
  4. I'm trying to find out exactly which models came with this. I've heard the 91-94 Turbo Legacy's have this. Is that right? I'm looking for this axle on the left.
