eqvance
Everything posted by eqvance
thanks for getting back with me. i hope it is the air mass rather than throttle body. i will take it to dealership and put on diagnostic machine. their is no check engine light on though. they will charge me about 120 bucks. i dont know much about throttle bodies, but they told me a new one would cost 600 bucks. its got to be some sensor, since its worse as the car engine heats up. also strange the the problem clears up with fuel injection additive. thanks for your time.
i know this is a subaru forum. besides my subaru, i've got a 1997 jetta 2.0 gas. it stumbles upon acceleration. i havent gotten much help from jetta forum. car smooths out as long as rpms are up. runs good when cold. also when adding gumout fuel injection the problem gets better. airflow meter or problem in throttle body? this forum has been great for my subaru. can anyone help with my jetta thanks
anyone out there have a good used 82 ea carbed engine for a 1986 gl wagon thanks
thanks miles, good to here from you again, wes
if you just moved to new castle, look for a guy named ''biker dave'', looks like sammy haggar, but with long long blond hair,usually braided. we were good friends when i lived up the frying pan outside of basalt. so you think that 1.6l will fit if the starter is on the drivers side?did some sking, but mostly dirt biking & fourwheeling, now i live down in the mississippi delta, i've got some farm land down here, about 1 hour below memphis. my place is about 10 minutes away from the famed ''crossroads'', where robert johnson made the deal with the devil
so if the starter is on the drivers side, it'll fit? hey, i used to live near rifle! i lived in carbondale. used to work for aspen earthmoving. i lived in that area for 17 years. i miss it very much.
will a 1.6l motor from a 1986 dl fit in a 1986 gl wagon that had a 1.8l in it?
anybody figured out how much a ea82 engine weighs?
just trying to get an idea of how much effort id take to pick one up
someone said id cooked my rings because i was getting smoke up from the air box. would not the plugs foul if that was the case. also motor is very hard to start. it keeps hitting but wont fire althoug sometimes it will. afraid im going to burn the starter up trying to crank it. 1986 gl wagon 2bl carb
anybody got an idea how much a EA82 2bl motor weighs?
i need a good used motor for 1986 gl subaru wagon. AE2 2BL. like i said before, i'm located in clarksdale mississippi, about an hour below memphis
has anyone out there got a used ea2 motor out ther for sale?
its an ea82
looks like this engine is shot. can anybody tell me how much to replace it ? 1986 gl wagon
also, there was still water in the block when it cooled
i think your probably right about everything, although i dont understand why i was getting oil in the breather before it ran hot. also , why do you think the car was bogging down to begin with?
was going down the road just fine, then it started to bog down it got worse as i pulled over i noticed the heat gauge going up but it never relly got that hot . afteri t cooled i noticed the top radiator hose had blown. replaced that & fianlly got it started. very little compression & smoke & oil coming from breather. ive noticed oil in the breather for about a week but the car was still running ok. anyway after i shut it down,smoke was coming from all parts of the engine, yet the gauge did not registerr hot. 1986 gl wagon
im about 90 percent sure ive g0ot a cracked head or blown gasket. but----after a week i fired it up. no more steam coming out the back and its running cool. i put a treatment of that liquid glass in last weekend , but it didnt work, at least not then.. like i said i let it sit for a week now it seems to be ok. although ive only run it short distances
can anybocdy tell me what the white plastic thing is beside the carb thoat . im thinking that's the reason i'm getting oil in my air breather. also would a cracked head cause valves to tap? 1986 gl wagon
i've got a cracked head or a blown gasket. how much should i expect to pay to repair? 1986 gl wagon
why is oil getting into my air breather & stopping up my air cleaner. what is that white, plastic deal right beside the carb throat?
car ran great for about 1000 miles after liquid glass treatment, now it's running hot again after driving about 60 miles. wondering if i should dump another bottle in, or keep driving and adding water till i have to repair head. what do you think?
i never new where the crak was. alli know is that i was getting steam out the tail pipe and losing water. so i tried this liquid glass & it worked. just wanted to see iff i could find some else that's used it to get an idea how long this stuff will hold. thanks
used liquid glass to repair a small crack in the head. how long do you think it'll last?
